Minimum Length of Emergency Escape Ramp for Truck to Stop
In summary, the problem involves a runaway truck with failed brakes on an emergency escape ramp with an inclination of 15°. The goal is to calculate the minimum length of the ramp needed for the truck to stop momentarily. Using the equations for mechanical energy, the correct formula is L = V1^2 / (2g sin(theta)), resulting in a minimum length of 260 m.
seraphimhouse
28
In Fig. 8-36, a runaway truck with failed brakes is moving downgrade at 130 km/h just before the driver steers the truck up a frictionless emergency escape ramp with an inclination of θ = 15°. The truck's mass is 1.2 x 104 kg. What minimum length L must the ramp have if the truck is to stop (momentarily) along it?
http://edugen.wiley.com/edugen/courses/crs1650/art/qb/qu/c08/fig08_35.gif
Mechanical Energy
E,mec = K + U
K = 1/2mV^2
U = mgy
Going through the problem I got K2 + U2 = K1 + U1 [2 being at the top of the inclined ramp and 1 being the bottom of the inclined ramp]. With substitution, I get:
1/2mv2^2 + mgy2 = 1/2mv1^2 + mgy1
Since velocity on the top of the ramp will equal zero and the length at the bottom of the ramp equals zero. the new formula will be:
gy2 = 1/2v1^2
subbing y2 with Lcos(theta):
Lcos(theta) = V1^2 / 2g
L = V1^2 / (2gcos(theta) )
I get an incorrect answer (247.97 m) The correct answer should be 260 m. Must be an misinterpretation somewhere. Any help would be nice :]
You don't know how to solve a right triangle by trig. Try again on that part. Most of your set up is fine.
eff me. sin(theta) no cos(theta) thanks.
1. How is the minimum length of an emergency escape ramp for trucks determined?
The minimum length of an emergency escape ramp for trucks is determined based on the vehicle's weight, speed, and braking capabilities. Calculations are done to determine the distance needed for a truck to safely come to a complete stop without causing damage or harm to the driver or surrounding areas.
2. Is there a minimum length requirement for all emergency escape ramps for trucks?
Yes, there is a minimum length requirement for all emergency escape ramps for trucks. This length varies depending on the location and terrain of the ramp, but it is typically between 200-400 feet.
3. Can a truck safely stop on an emergency escape ramp if it is shorter than the recommended length?
No, a truck cannot safely stop on an emergency escape ramp if it is shorter than the recommended length. The recommended length is calculated to ensure that a truck can come to a complete stop without causing damage or harm.
4. Are there any regulations or standards for the minimum length of emergency escape ramps for trucks?
Yes, there are regulations and standards set by organizations such as the Federal Motor Carrier Safety Administration (FMCSA) and the American Association of State Highway and Transportation Officials (AASHTO) for the minimum length of emergency escape ramps for trucks. These regulations and standards ensure the safety of drivers and surrounding areas.
5. Can the minimum length of an emergency escape ramp for trucks vary depending on the type of truck?
Yes, the minimum length of an emergency escape ramp for trucks can vary depending on the type of truck. Different trucks have different weights and braking capabilities, so the recommended length may differ for each type of truck. It is important to consider these factors when determining the minimum length of an emergency escape ramp for a specific type of truck.
15K
