True or False
  • Thread starter cyprusx
cyprusx
The magnitude of the current depends on the rate at which the magnet is moving in and out of the solenoid.
True or false
Answers and Replies
HallsofIvy
43,021
970
Have you considered flipping a coin?
Now you know you are expected to make some effort yourself. In this case, I assume you are talking about a generator consisting of a magnet moving inside a coil- You should have said that. What does your textbook say about generators? What formulas do you know for current?
semc
361
since voltage induced is proportional to the rate of change of B-field,i think magnitude is also dependent on it?
cyprusx
i really have no clue, I am a noob
Hootenanny
Staff Emeritus
Consider Faraday's Law together with Ohm's law.
cyprusx
man, i have too hand this in tomorrow and I am at risk of failing can you cut a guy a break
Hootenanny
Staff Emeritus
I will help you, but I am not going to give you the answer. However, if you do put some effort in, you will have the answer within minutes. Now, what is Faraday's law?
cyprusx
Any change in the magnetic environment of a coil of wire will cause a voltage (emf) to be "induced" in the coil.
Hootenanny
Staff Emeritus
Correct, this can be represented mathematically;
[tex]V=\frac{\Delta\Phi}{\Delta t}=\frac{\Delta (BA)}{\Delta t}[/tex]
Next, what is ohm's law?
cyprusx
Ohm's law states that, in an electrical circuit, the current passing through a conductor is directly proportional to the potential difference applied across them provided all physical conditions are kept constant.
Hootenanny
Staff Emeritus
And mathematically;
[tex]I = \frac{V}{R}[/tex]
So, can you now combine the two equations?
As an aside, I do hope that you are taking the time to understand these laws and are simply not copying and pasting them directly from the internet.
cyprusx
how do you comine them
Hootenanny
Staff Emeritus
Substitute Faraday's law for the V in ohm's law.
cyprusx
cant you help a guy out
Hootenanny I am studying for a test right now that's in an hour i really don't have time.
Hootenanny
Staff Emeritus
I will do the substitution for you, however, you must draw your own conclusions. So now we can say that;
[tex]I = \frac{\frac{\Delta (BA)}{\Delta t}}{R} = \frac{\Delta (BA)}{R\cdot\Delta t}[/tex]
Now, if you change that rate at which you move the magnet through the coil, do any terms change in the above equation?
cyprusx
yes they do
Hootenanny
Staff Emeritus
cyprusx
yes
so my initial question is False
cyprusx
or...
Hootenanny
Staff Emeritus
If the current does change when you change the rate at which the magnet moves then the above statement is ____
cyprusx
true...
Hootenanny
Staff Emeritus
cyprusx
Hootenanny does the magnitude of the current depend on the strength of the magnet.
P.S because weave formed such a close friendship over these past hours do you think you might be able to answer my other question... pleaseeeeee
HalfManHalfAmazing
54
is this for real? you are studying for a test and can't combine 2 equations? is this grade 11 or something?
cyprusx
yeah....
Hootenanny
Staff Emeritus
What do you think? Look at the equation we derived above.
Suggested for: True or False
  • Last Post
  • Last Post
