Solving the Truss Bridge Problem
In summary, the conversation discusses the analysis of a truss bridge with a 1000N force applied 3/4 of the way across. Different methods of resolving the forces result in two different values for T4, leading to a discussion of the correct way to apply forces at joints and use the method of sections for consistent results.
BridgeBuilder
First time poster, long time reader...
Consider the truss bridge as shown in the attached diagram (Each member is the same length) A force of 1000N is applied 3/4 of the way across the bridge. We get:
R1 = 250 N
R2 = 750 N
Resolving from the left we get:
T1 = 250 / sin 60
T1 sin 60 = T3 sin 60 so T1 = T3
T4 = T1 cos 60 + T3 cos 60
so T4 = T1 = T3 = 250 / sin 60
However, resolving from the right we get:
T7 = 750 / sin 60
T7 sin 60 = T5 sin 60 so T7 = T5
T4 = T5 cos 60 + T7 cos 60
so T4 = T5 = T7 = 750 / sin 60
Why do we get two different values for T4? I cannot see my mistake.
Many thanks.
Forces must be applied at joints. You could break up the 1000 N to 500 N on both joints for that member. You will see that the solution you found in your analysis from the left side is correct.
The forces don't have to be applied to the joints. You can cut the structure right down the middle. Using the method of sections, and taking moments for each side about the centre bottom joint gives consistent values of T4.
1. How do you determine the best design for a truss bridge?
The best design for a truss bridge is determined by considering various factors such as the location, span length, load capacity, and budget. Engineers use mathematical models and computer simulations to analyze different design options and determine the most efficient and cost-effective solution.
2. What are the main challenges in solving the truss bridge problem?
The main challenges in solving the truss bridge problem are balancing the structural integrity and load capacity with cost-effectiveness, considering environmental factors such as wind and seismic activity, and ensuring the safety and longevity of the bridge.
3. What materials are commonly used in truss bridge construction?
The most commonly used materials in truss bridge construction are steel, concrete, and wood. Steel is preferred for its strength and durability, while concrete offers high load-bearing capacity. Wood is commonly used for smaller bridges due to its cost-effectiveness.
4. How do you determine the load capacity of a truss bridge?
The load capacity of a truss bridge is determined by analyzing the forces acting on the bridge, such as the weight of the bridge itself, the weight of the traffic and environmental loads, and the strength and stability of the bridge structure. Engineers use mathematical models and computer simulations to calculate the load capacity and ensure that it meets safety standards.
5. How do you ensure the safety of a truss bridge?
The safety of a truss bridge is ensured through rigorous testing and inspection during the design, construction, and maintenance phases. Engineers use safety factors and load testing to ensure that the bridge can withstand expected loads and environmental conditions. Regular inspections and maintenance also help to identify and address any potential safety hazards.
