timeforplanb
- 17
Why do TTL integrated circuits assume unconnected inputs to be at logic level HIGH? Does the answer lie in the circuitry itself or some other factor?
vk6kro said:
In the diagram, the inputs are only low if current flows out of the device at A or B. Otherwise, they are high.
If either of the inputs is grounded, then the output transistor will not get base current so the output will be high.
Only if both inputs are not grounded, ie high, then the output will be low.
timeforplanb said:I'm not that familiar with the internal circuitry of TTL gates yet. In the diagram, Vcc is one of the inputs right? Where is the other one? Do A and B represent the output terminals?
So, if the input is grounded we know that it goes through a certain circuit so we expect its output voltage to be low? Otherwise, it is high?
A TTL (transistor-transistor logic) gate circuit is an electronic circuit that uses transistors to process and transmit digital signals. It is commonly used in digital devices such as computers and microcontrollers.
A TTL gate circuit consists of multiple transistors connected in a specific arrangement to perform logical operations on input signals. The output signal is determined based on the state of the input signals and the logic function of the specific gate (AND, OR, NOT, etc.).
Unconnected inputs refer to input pins on a TTL gate circuit that are left floating, meaning they are not connected to either a logic HIGH (1) or logic LOW (0) signal. These unconnected inputs can cause unpredictable behavior in the circuit and should be avoided.
When unconnected inputs in a TTL gate circuit are left floating and have a logic level HIGH (1), they can act as antennas and pick up stray electrical signals, causing false inputs and output errors. Therefore, it is important to connect all inputs to a known logic level (either HIGH or LOW) to ensure proper operation of the circuit.
To prevent issues with unconnected inputs in a TTL gate circuit, it is important to properly design and test the circuit before use. This includes connecting all inputs to a known logic level, minimizing the length of the input wires, and using decoupling capacitors to reduce noise. It is also important to follow the manufacturer's guidelines and datasheets for the specific TTL gate circuit being used.
