What was the purpose of the small button on tube television receivers?
In summary, a button or dial on an old television set could be used to improve reception by removing any secondary magnetic field that may have built up on the screen.
homerwho
42
TL;DR Summary
I had an old dial tune TV set. Obsolete now.
It had a small button that I think was suppose to improve reception. What did that button do physically?
"Tube"? How old was it? The button is probably a "degausser". Theoretically it removed any secondary magnetic field that could build up on the screen. I don't think it was ever clear how useful that was,
It was from the late eighties
I have another question. If I tuned that to channel 11 but l don’t have signal. What is displayed. I realize it’s static. But is the static the same channel to all without a broadcast?
homerwho said:
Summary: I had an old dial tune TV set. Obsolete now.
Button or dial? It was common to have a "fine tune" dial control on those early sets, since they did not have frequency synthesizers and other ways of making very accurate frequency adjustments.
Likes Delta2
Dial. It had a button that when pressed it would latch. It did have the fine tune knobs
Likes 256bits
"Well, which is it young feller?" (Quiz Question -- what movie is that from?) :smile:
The "Improve Reception" control was a fine-tune dial or a single push-button?
Likes homerwho
I don’t recognize the quote. But it is humorous.
It had the push to fine tune wheel around each dial. But it had a three position push button. Well old timer what do you think the change was. It never did didly swat. I’m interested in what it was. The Degause was a one press and done. This set had intermediate position on the button
Likes berkeman
:smile:
My guess would be either a fine tune on the frequency, or a change in the AGC range.
Likes Klystron
Possibly Automatic Fine Tuning, AKA: AFT.
Likes Klystron and Delta2
I assume that's a typo, yes? Or is there some part of the country where "diddly squat" is "didly swat" ?
  • Haha
Likes berkeman
I never knew a television that did have a de-gausser button on the unit, and I have known a few.
It is whatever electromagnetic noise there is at the frequency of the channel. That noise will vary from channel to channel and from one location to another.
So you were receiving VHF signals, channels 2 -13.
Any UHF channels 14 -69?
Actually, our first color TV back in the 70's had one. It was a momentary contact button, and when you pushed it, the picture would jump and wriggle, as if it was a reflection in a pond you had dropped a pebble into. It would settle down in a couple of seconds, with possibly some change in the color. IIRC, it was supposed to counteract accumulated magnetization of the chassis and picture tube.
As did my first trinitron computer monitor. Not sure its the switch in question
Likes russ_watters
A picture would help.
My humble bet is that it was the VHF/UHF selector.
I can't recall what was the usual third position. Maybe the composite input?
I'm sorry but the set went to the landfill for recycling. it had a UHF dial and fine tuner and a VHF dial with fine tuner that was much slower at adjustment. It had a volume knob. And below that was this rectangular small button. It was a Panasonic from the 80's. The difference to the picture was negligible however the physics of the reception would be interesting. on /off
A quick Google Images search on Panasonic TV 1980s turns up some possibilities. Here is the CT9010, which does indeed have an AFT button...
http://vintageelectronics.betamaxcollectors.com/panasonictelevisionsetmodelct9010.html
https://en.wikipedia.org/wiki/Automatic_frequency_control
Likes homerwho
Yeah that's basically it. Is there a digital complement?
Did you read the Wikipedia link? It does mention what happened when digital frequency synthesis was introduced... :smile:
Likes Averagesupernova
Sorry if I got ahead of myself. I didn't see the Wiki link. Thank you. Is what I needed to read. Thanks
Likes berkeman
That's my bad. The link was kind of hidden at the end of my post after the picture. :smile:
If you can I seem to have narrowed it down a lot. on topic now. Is it a tracking function of some kind? Thanks for the kind correction on the wiki
That is my impression, although I've never designed that particular kind of circuit (I've designed PLLs, which are a related type of circuit though).
My impression from the Wikipedia article is that the feature is used to help stabilize the tuner's lock-in to a channel once is is tuned well. It helps to prevent drift of those old tuner circuits with temperature and time as you stay tuned to the same channel. So I'm guessing (somebody find the old manual please?) that you would change the channel knob to the channel you wanted, turn the Fine Tuning knob to get centered on the broadcast signal, and then turn on the AFT/AFC.
As long as the TV was still turned on, that would help to keep the TV tuned right on the frequency of that chosen channel. If you wanted to change channels or if you turned the TV off and later turned it back on, you would need to do the fine-tune knob (with AFC off) again first, and then re-engage AFC. But that's just my educated guess, unless somebody can remember better or find an old TV manual...
Wikipedia said:
In radio equipment, Automatic Frequency Control (AFC), also called Automatic Fine Tuning (AFT), is a method or circuit to automatically keep a resonant circuit tuned to the frequency of an incoming radio signal. It is primarily used in radio receivers to keep the receiver tuned to the frequency of the desired station.
And maybe this is why it didn't seem to do much. If you try to use it to improve the picture right away, that's not what it was for. It was to keep the picture tuned well as you watched the same channel for a while (especially right after you turned the TV on and the tuner circuit wasn't warmed up yet).
Likes homerwho and Klystron
I really appreciate the dialog. It wasn't;t explained to enable after a fine tune. It's a bit nostalgic to ask what did that 30 year old tv button do. But shoot the people that knew maybe thinning.. Thank you 😊😊😊
Likes berkeman
I have to dig in some old television/video books but I suspect the AFT was a form of PLL. Probably compared the IF signal against a 'standard' xtal oscillator in the TV set. I won't say any more until I can verify.
Likes Klystron and berkeman
Paging @davenn and @dlgoff :smile:
  • #31
I didn't find what I wanted in my TV systems/video book but I will mention a few other things.
I didn't think the day would come when I would have to explain how a manual TV tuner worked but here goes:
Suppose I turn the selector to channel 4 and dial around the fine tuning control to make the picture come in nice and clear but then decide channel 4 is broadcasting crap so I turn to channel 10. Now again I need to adjust the fine tuning but alas, it turns out that channel 10 is spewing out even more crap so, back to channel 4. I will NOT need to readjust the fine tuning. Each channel has it's own tuned circuit with an adjustable element. Fine tuning one channel does not affect the fine tuning on a different channel. You are actually tuning different components.
Where AFT comes in is correcting for drift over the temperature range while the receiver warms up. If it is turned on it will take care of frequency drift within reasonable specs. I know that cable companies in the past have shifted the carrier frequency from 'standard' on some channels to avoid some interference. AFT will take care of this.
Here is a link to a tutorial in PDF form for piece of test equipment used to service older TV sets. It includes a quick test for the AFT function of a TV receiver.
http://www.google.com/url?sa=t&rct=...-%205283.pdf&usg=AOvVaw0zKLgs4OK1t5TpXx9MaTl6
Likes DrClaude and berkeman
  • #32
My guess, is the button.. bypass or applies the fine tune-if it be auto or knob adjusted...
  • #33
Welcome to the PF.
Did you read any of the posts in the rest of this thread? Or just the first one... :smile:
Likes Tom.G and Averagesupernova
  • #34
Welcome to the PF.
Sorry i just replied to the first question. I scrolled through the posts. Didnt see anything lf bypass /engage button.. sorry if i missed it. I registered just now as i recognise a gold source. I am still to fill oit my profile.. apologies, i don't get offended.. if I am ever in the wrong. Just tell me... i like to be wrong, it the only possible condition to deliver true learning. No game of ego confirming for me. Shoot me Down at every sight... there's nothing greater. Nice to meet yall, sorry. I know this isn't the right place.. ill go intro in rhe correct section.🖖😋
  • #35
No worries, we're glad to have you here. Enjoy the PF! :smile:
  • Quantum Physics
  • General Engineering
  • DIY Projects
  • Other Physics Topics
  • Mechanical Engineering
