What is the upward velocity of a tennis ball after bouncing off a volleyball?
  • Thread starter subwaybusker
  • Tags
    Balls
In summary, a 0.25kg tennis ball and a 1kg volleyball collide in an elastic collision. The tennis ball is placed on top of the volleyball and both are dropped, resulting in a speed of 3 m/s for both balls when they hit the ground. The question asks to find the upward velocity of the tennis ball after it bounces off the volleyball. To solve this, we can use conservation of momentum and conservation of energy. It is important to note that the ground and Earth can be treated as infinitely massive, so we can ignore their contribution to momentum. Setting the reference frame to that of the tennis ball, we can use conservation of momentum to find the velocity of the tennis ball after the collision. Then, converting back
subwaybusker
51
A 0.25kg tennis ball is placed right on top of a 1kg volleyball and dropped. Both balls hit the ground at a speed of 3 m/s simultaneously. Find the (upward) velocity of the tennis ball right after it bounces up from the volleyball. Assume elastic collisions. (HINT: the tennis ball will move faster than 3m/s)
mass of tennis ball=0.25kg
mass of volleyball = 1kg
1) Va'=Va(m1-m2)/(m1+m2)
2) Vb'=Va(2m1/(m1+m2)
Someone told me that when the two balls hit the ground, the volleyball reverses direction...so -3m/s? Plus it's an elastic collision, so kinetic energy and momentum are both conserved. But initial velocity of volleyball is not zero, so i can't use eq'ns 1 or 2 above? If i set the velocities of the balls to the reference frame of the tennis so that the velocity of the volleyball is zero will that work out?
Also, I'm not really sure why only the volleyball reverses direction, if both of them are simulataneously released then shouldn't they hit the ground at the same time? and why does the volleyball rebound when the collision occurs? shouldn't all the kinetic energy of the volleyball be transferred to the tennis ball since the volleyball is sandwiched between the Earth and tennisball so that it's velocity is zero?
Hi subwaybusker! :smile:
subwaybusker said:
… it's an elastic collision, so kinetic energy and momentum are both conserved.
Not entirely … kinetic energy is conserved, but momentum involving the wall isn't.
Hint: pretend that the volleyball is well in front of the tennis ball … it bounces off the wall, and hits the tennis ball … then momentum won't be conserved in the first collision (with the wall), but will be conserved in the second one! :smile:
why won't momentum be conserved in the first collision? if not then why is kinetic energy conserved?
Momentum is conserved (of course) if you include the ground and attached Earth in your calculations. But it's a safe assumption to treat the mass of such as infinitely higher than that of the volleyball. The momentum of the volleyball alone is not conserved.
KE is conserved because the collision is assumed to be elastic and because the ground/earth can be treated as infinitely massive.
okay, i get why KE is conserved. as for momentum, do you mean that when the volleyball hits the ground, some momentum is transferred to the earth?
what do i do to solve this question?
if momentum is not conserved for the first equation, then i don't have the momentum of the volleyball after it hits the ground. does that mean i can only use kinetic energy to solve for the second collision?
Sure.
You can figure out the momentum using conservation of energy, if you need to.
The practical answer is that momentum obviously isn't conserved when something bounces off a wall … the wall has the same momentum before as after, while the bouncing thing doesn't!
The technical answer is that momentum is conserved, because the wall does move slightly … but it takes the whole of the Earth with it! :smile: If we had a stationary frame of reference in outer space, then we could see that. However, since our frame of reference is attached to the Earth … the examiner, after all, is expecting a speed relative to the Earth … we can't use conservation of momentum!
erm … because the question tells you it is! :smile:
(usually, it isn't conserved in collisions.)
How are you getting on with the equations? :smile:
volleyball:
M=1kg
V=-3m/s [down]
tennis ball:
m=0.25kg
v=3 m/s [down]
Set the reference frame to that of the tennis ball so that v=0m/s
V=-6m/s v=0m/s
Using conservation of momentum for the second collision:
MV+mv=MV'+mv'
(1kg)(-6m/s)+0=(1kg)V'+(0.25kg)v'
I don't know what to do afterwards?
Whyever are you changing the frame of reference?
The question asks you for speed relative to the Earth, doesn't it?
You'll only have to convert back again … plus there's the chance of making a mistake when you do convert back! :frown:
Anyway, whichever frame you use, as Doc Al says, you must use both conservation of energy and conservation of momentum!
Have a go! :smile:
1. What is the definition of momentum?
Momentum is a measurement of an object's motion, determined by multiplying its mass and velocity. This means that the more mass an object has and the faster it is moving, the greater its momentum will be.
2. How is momentum calculated?
Momentum is calculated by multiplying an object's mass (m) by its velocity (v), using the formula P = mv.
3. What happens to momentum when two balls collide?
When two balls collide, their momenta are transferred to each other. If the two balls have different masses, the ball with the greater mass will have a smaller change in velocity compared to the ball with the smaller mass.
4. Can the total momentum of two balls change in a collision?
No, the total momentum of two balls in a collision remains constant. This is known as the law of conservation of momentum, which states that in a closed system, the total momentum before an event must be equal to the total momentum after the event.
5. How does friction affect the momentum of two balls?
Friction can decrease the momentum of two balls in motion by causing them to slow down. This is because friction acts in the opposite direction of motion, reducing the velocity and therefore the momentum of the balls.
