Two Blocks and Pulley
conniechiwa
50
A block of mass m1 = 3 kg rests on a table with which it has a coefficient of friction µ = 0.7. A string attached to the block passes over a pulley to a block of mass m3 = 5 kg. The pulley is a uniform disk of mass m2 = 0.4 kg and radius 15 cm. As the mass m3 falls, the string does not slip on the pulley.
With what acceleration does the mass m3 fall?
What is the tension in the vertical string, T3?
https://online-s.physics.uiuc.edu/cgi/courses/shell/common/showme.pl?courses/phys101/fall07/homework/09/07b/7.gif [Broken]
I'm not sure how to do this...
Answers and Replies
learningphysics
4,099
It's like the regular pulley problems except that the pulley isn't massless... hence you have to take its moment of inertia into account.
net torque about the pulley is I*(angular acceleration).
conniechiwa
50
I found T1, which is 31.23 N, but I don't know how to find T3 from it since the tensions are not equal.
learningphysics
4,099
How did you get T1?
conniechiwa
50
umm i don't remember how i got T1, but that is the answer.
learningphysics
4,099
ok. first get the acceleration of m1 to the right... that's the same acceleration that m3 has downward.
use that acceleration to get T3.
conniechiwa
50
I tried doing that, but I'm not getting the right answer:
T1-FF =ma
T1 - uk*N = ma
T1-uk*mg = ma
31.23N - (0.7*3kg*9.8m/s^2) = (10kg) a
a =1.065 m/s^2
learningphysics
4,099
T1-FF =ma
T1 - uk*N = ma
T1-uk*mg = ma
a =1.065 m/s^2
why are you using 10kg?
conniechiwa
50
Oh oops, but even after using 3kg it doesnt work either..
T1-FF =ma
T1 - uk*N = ma
T1-uk*mg = ma
31.23N - (0.7*3kg*9.8m/s^2) = (3kg) a
a =3.55 m/s^2
learningphysics
4,099
Are you really sure about the 31.23 N? Did that answer get accepted by the computer?
conniechiwa
50
yeah the 31.23 N got accepted by the computer.
conniechiwa
50
i think what i did originally was substitute T3 in order to find T1 and I somehow got that answer and it worked. but i guess T1 and T3 are not equal.
learningphysics
4,099
"With what acceleration does the mass m3 fall?
What is the tension in the vertical string, T3?"
so the question didn't ask for T1... and you entered 31.23 for T3?
T1 and T3 are not equal... if you already have T3... then calculate the acceleration of m3 from that...
you just need the acceleration of m3 and T3 right?
conniechiwa
50
the question asked for T1 and I got it. But now I need T3 and m3.
learningphysics
4,099
Your answer for T1 is close (letting it get accepted by the computer), but not exact which is why the other answers aren't going through... I recommend solving from scratch... and getting all the values from the beginning...
Suggested for: Two Blocks and Pulley
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
9K
  • Last Post
  • Last Post
18K
  • Last Post
  • Last Post
11K
  • Last Post
