Homework Help: Two blocks attached
  1. Jan 18, 2014 #1
    Two blocks with masses m1 and m2, m2>m1, are attached, I push from the left and from the right side, which force is bigger? The surface is frictionless.
    http://imagizer.imageshack.us/v2/800x600q90/194/wkft.png [Broken]
    2. The attempt at a solution
    I think it's bigger when applied from the left because of the reaction of m2 is bigger than the reaction of m1 because m2>m1, but I don't know any equations to corroborate it.
  3. Jan 18, 2014 #2
    tiny-tim
    hi thonwer! welcome to pf! :smile:
    i don't understand the question, there seems to be something missing :redface:
    why can't the forces be whatever you want? :confused:
  4. Jan 18, 2014 #3
    The force I have to consider is the arrow drawn in each case because it is what they ask me, the picture is part of the formulation.
    What I mean on the question is, in one case I push from the left, in other case I push from the right. In which case the force is bigger so as to move the blocks?
  5. Jan 18, 2014 #4
    tiny-tim
    hi thonwer! :smile:
    but the picture shows the same letter, F, for both forces, which presumably means that they are equal :confused:
    do you mean which acceleration is bigger?
  6. Jan 18, 2014 #5
    Ok sorry, I did not explain myself quite well, the Force applied is the same in both cases.
    The correct question would be, which reaction force is bigger?
  7. Jan 18, 2014 #6
    tiny-tim
    ahhh! :smile:
    well, as you probably know, the acceleration is the same in both cases
    so do good ol' Newton's second law for the block that the force F isn't on in each case …
    what do you get? :wink:
  8. Jan 18, 2014 #7
    I didn't understand you sorry, English is not my first language,
    what did you want to say with "do good ol' Newton's second law for the block that the force F isn't on in each case" ?
  9. Jan 18, 2014 #8
    tiny-tim
    sorry! :smile:
    in the first picture, the force F is on the left, pushing on the smaller block
    so do the equation "force = mass times acceleration" (ie Newton's second law) for the larger block
    (and then do the same for the smaller block in the second picture)
  10. Jan 18, 2014 #9
    For 1: F-R=m1*a -> R=F-m1*a
    For 2: F-R=m2*a -> R=F-m2*a
    F is the same, a is the same => m1*a<m2*a so R in 1 is bigger
    Is it correct?
  11. Jan 18, 2014 #10
    tiny-tim
    yes! :smile:
    (though it would have been slightly quicker to do the other block in each case:
    For 1: R=m2*a
    For 2: R=m1*a :wink:)​
Have something to add?
Draft saved Draft deleted
