ssgohan434
- 3
SOLVED :)
https://tycho-s.phys.washington.edu/cgi/courses/shell/common/showme.pl?courses/phys114/winter08/homework/04d/2blocks_incline_NWT/5.gif
The figure shows two identical blocks tied together with a string which passes over a pulley at the crest of the inclined planes, one of which makes an angle q1 = 30° to the horizontal, the other makes the complementary angle q2 = 60°.
a) If there is no friction anywhere, with what acceleration do the blocks move?
b) If each block has a mass m = 1 kg, what is the tension in the string while they are both moving?
c) Now suppose the coefficient of sliding friction between the blocks and planes is µ = 0.02. With what acceleration do the blocks move in this case?
F = ma
Hint for a): Draw a free-body diagram for each block. Using your free-body diagram and F = ma for each block, find two equations and two unknowns, the unknowns being the acceleration (part (a)) and the tension (part (b)).
My freebody diagrams for the box on the left (which I labeled box 1) included a perpendicular normal force, gravity straight down, and tension up the box.
My freebody diagram for the box on the right (box 2) included gravity down, normal force perpendicular to the plane, and tension toward the incline of the plane.
So the equation I came up with:
F=ma --->
F(box1) = Ftension - mg(sin30)
F(box2) = mg(sin60) - Ftension
and that is all I've been able to come up with for the past hour of racking my brain :( . I was hoping someone could point me in the right direction. Much appreciated!
F = ma
F=ma --->
