Two blocks over a pulley
  • Thread starter oneamp
oneamp
219
The figure shows a 100 kg block being released from rest from a height of 1.0 m. It then takes 0.90 s to reach the floor. What is the mass of the block on the left?
Illustration shows a pulley connected to the ceiling, with a block of 100 kg on the right, and a block of unknown mass on the left.
I used this to find acceleration of the system:
0 = 1 + (0.5)(a) [(0.90)^2]
a = (-2.5) m/s^2
I drew a diagram. F_G on the bottom, 100 * 9.8 = 980N down.
F = ma so (100)(2.5) = 250, and that must mean that the vector pointing up in my diagram will be 730N (980 - 250 = 750).
So, the 750 comes from the other block. F = ma again, solve for m I get 292 kg, which is not the right answer.
Where did I go wrong?
Thank you
Answers and Replies
nasu
3,957
582
a = (-2.5) m/s^2
Up to here is (almost) OK.
You found the tension in the rope. It is not clear if it's 730N or 750N (it depends on taking g=9.8 or 10 m/s^2).
Thank you
Now write Newton's second law for the other block. You know the tension in the rope and the acceleration (same as for the first block).
Legaldose
74
The way I deal with Atwood problems is to first translate the vertical forces to horizontal ones, it makes it easier for me to deal with the forces involved, and gets rid of the confusion of having the pulley. Here's a picture of what I mean. Try applying Newton's Laws to the system on the right.
oneamp
219
Thank you :)
Suggested for: Two blocks over a pulley
  • Last Post
  • Last Post
9K
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
17K
