Two boxes on two slopes
  • Thread starter springo
http://img15.imageshack.us/img15/407/draw.th.png [Broken]
Initially m and m' are at rest and at the same height. The planes are perpendicular. Find the minimal distance that separates m and m'.
Well the distance that separates them is the length of the vector that describes m 's position relative to m'. But then I fail to find any idea on how to get to that vector.
Thanks for your help.
Answers and Replies
square root of (a cos (alpha)2 + a sin ( alpha) 2)
AEM
360
Make you origin at the intersection of the two planes; choose the y axis along the line from O to m' and the x axis along the line from O to m. Then m is located at
[tex] - a cos(\alpha) \mathbf{i} [/tex]
and m' is located at
[tex] a sin(\alpha) \mathbf{j} [/tex]
Then you can figure out the vector from m to m'.
I'm not sure how the previous post helps you since the a factors out and
[tex] sin^2(\alpha) + cos^2(\alpha) = 1 [/tex]
leaving you with something you already knew.
Thanks for the replies.
I'm sorry, but I think I didn't explain myself correctly.
The thing is the boxes move down the slopes, so at some point either
- m hits O
- m' hits O
(whichever happens first)
So at that moment mm' has a certain length, say d. What I'm looking for is that length which probably is a function of α and a.
rl.bhat
4,433
First of all find the component g along the inclined planes, and the lengths of the inclined planes. From the figure it is clear that m hits O first. From the component of g and the
length of the inclined plane, find time taken by m to reach O. Using this time find how much m' moves downward. Knowing the length of the inclined plane containing m', you can find the distance mm'.
Gokul43201
Staff Emeritus
This is not the right way to solve this problem. First of all, one does not know which block hits O first since the angle \alpha is not specified.
To springo:
1. It does not matter which block hits O first.
2. Can you write and equation that describes the position of m (and hence, also m') as a function of time, t?
3. If you have expressions for the positions of m and m', then you should also be able to deduce an expression for the distance between m and m' as a function of t.
4. What is the last thing you need to do?
Well, I guess we could find the expressions of OM and OM' as a function of time using the acceleration or the speed and integrating. Let (O, i, j) be (O, uOM ,uOM')
OM = (a·cos(α) - (1/2)·g·sin(α)·t2) j
OM' = (a·sin(α) - (1/2)·g·cos(α)·t2) i
Is that what you suggested?
Thanks.
Gokul43201
Staff Emeritus
Thanks.
Good. That's exactly correct so far.
Now, isn't there a very simple geometric rule you can use to find the distance (MM') between the two blocks?
PS: Alternatively, if you wish to stick with vectors, you can arrive at this same result by finding the vector MM' out of OM and OM' and then computing its magnitude.
Yeah, sure:
d2 = (a·sin(α) - (1/2)·g·cos(α)·t2)2 + (a·cos(α) - (1/2)·g·sin(α)·t2)2
d2 = a2 - a·g·sin(α)·cos(α)·t2 + (1/4)·g2·t4
I had written that down before, but since it wasn't leading me anywhere I thought something was wrong.
Gokul43201
Staff Emeritus
I have an extra factor of 2 on the middle term - can you check that?
Gokul43201
Staff Emeritus
Next up, you want to find the minimal value of d^2. The way you tackle that depends on whether or not you've had differential calculus. Have you?
If you have, what do you think you should do?
d2 = a2 - a·g·sin(2α)·t2 + (1/4)·g2·t4
OK, so since d > 0, the minimum value for d is also the minimum value for d2. So we could take the derivative of that.
d(d2)/dt = 2·a·g·sin(2α)·t + g2·t3
But then I get three roots, the interesting one leaves us with:
gt2 = 4·a·sin(α)·cos(α)
We replace in the first equation and simplify:
d2 = a2·cos2(2α)
d = a·cos(2α)
Is that it? Thanks!
Gokul43201
Staff Emeritus
Looks good.
But just for good form you may need to do one final thing to demonstrate that this is indeed a minimum and not a maximum (well, it's obviously not a maximum since acos(2alpha) < a, which was the initial separation, but it's good to develop the practice of identifying the type of optimal value). Do you know how you would do this?
The next derivative is f'' (so 2nd, which is even) and it's negative, so it's a maximum. Is that correct?
Thanks again!
Related Threads on Two boxes on two slopes
  • Last Post
  • Last Post
  • Last Post
  • Last Post
48K
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
