Two-dimensional Kinematics
  1. Apr 25, 2014 #1
    A stunt driver wants to make his car jump over 8 cars parked side by side below a horizontal ramp (Fig. 3–41). (a) With what minimum speed must he drive off the horizontal ramp? The vertical height of the ramp is 1.5 m above the cars and the horizontal distance he must clear is 22 m. (b) If the ramp is now tilted upward, so that “takeoff angle” is 7.0° above the horizontal, what is the new minimum speed?
    2. Relevant equations
    [tex]y=y_0+v_0t+.5at^2[/tex]
    [tex]v^2=v_0^2+2a(y-y_0)[/tex]
    [tex]x=v_0t[/tex]
    3. The attempt at a solution
    The answer to part a is obviously 40m/s, but the answer to b eludes me.
    I need v, so I defined v_x in terms of v via the kinematic equation [tex]x=v_0t[/tex]
    and then solved it for t
    [tex]22=tcos\theta[/tex]
    [tex]t=\frac{22}{vcos\theta}[/tex]
    However, when I attempt to do this with v_y, I end up with a nasty quadratic
    [tex]-4.9t^2+tvsin\theta+1.5=0[/tex]
    and solving this for t does not seem to be advisable.
  3. Apr 25, 2014 #2
    SammyS
    Staff Emeritus
    Hello, ciubba. Welcome to PF !
    Why do you consider that quadratic equation to be nasty ?
    You know that θ = 7° . Right ?
    You should probably solve the other equation for t, in terms of v, then substitute that back into the quadratic, so there's only one variable.
  4. Apr 25, 2014 #3
    I can't believe that never occurred to me-- I was going to solve them both for t, then set them equal to each other.
    The answer is 23.88, which rounds to 24m/s with significant digits. Thanks!
Have something to add?
Draft saved Draft deleted
Similar Discussions: Two-dimensional Kinematics
Loading...
