Two-Dimensional Motion
  • Thread starter frozen7
frozen7
163
A stone is thrown upward from the top of a building at an angle of 30 degree to the horizontal and with an initial speed of 20m/s. The height of the building is 45m.
How long is the stone "in flight"?
Solution:
Vx0 = 20cos30 = 17.3
Vy0 = 20sin30 = 10
-45 = 10t - 1/2 g t^2
t = 4.22s
This is an example from my physics textbook. I wonder why the solution is in this way. Why the time used to reach the highest level and the time from the highest level to the initial position are not considered as time "in flight"?
Thanks.
Answers and Replies
marlon
3,777
Solution:
Vy0 = 20sin30 = 10
t = 4.22s
Thanks.
The solution is correct.
I do not get your question though. The time to reach maximal height is also considered to be time in flight. Why do you get this idea. Besides, the time to get to max height is not calculated here, you are just calculating the time it takes for the vertical y-coordinate to go from 45 to 0. That is all, and that is ofcourse the complete motion.
The general formula in this case is [tex]y=y_{initial} + v_{initial}t -gt^2/2[/tex] and y=0 here
marlon
frozen7
163
Then what does "time in flight" actually mean?
Not from the time it is thrown until it reaches the ground?
marlon
3,777
yes the time it is thrown until it reaches the ground's surface
marlon
HallsofIvy
43,021
970
If you were to graph y= 10t - 1/2 g t2 the graph would be, of course, a parabola. (Since the x motion is linear, x= 17.3t, the actual path is a parabola.)
It starts at (0, 0) rises to some maximum, then falls to (4.22, -35). You may be thinking that you calculate the time going up, then the time going down and add but that is not necessary: solving y= -35= 10t- (1/2)gt2 gives the total time immediately. Notice that a quadratic equation has two solutions (the other solution with y= -35 is negative and so not a "time in flight"). If you took y positive but less than the maximum height, your quadratic equation would have two positive solutions: the smaller the time at which the stone passes that height going up, the larger, the time the stone passes that height on its way back down. What do you think would happen if you set y equal to a number greater than the maximum height and solved for t?
marlon
3,777
This is not the correct formula.
It is : [tex]y=45 +10t -gt^2/2[/tex]
If you chose the origin just at the bottom of the building, this get easier in my opinion. The above formula is based upon this assumption
marlon
mukundpa
524
The time of flight is simply the time for which the object remains in air and moving under gravity. Here it is from the top of the building to the ground and the time to reach the maximum height is not equal to the time from max height to the ground. For ground to ground both distances are equal. I think Frozen 7 required that much only. Is it?
Suggested for: Two-Dimensional Motion
  • Last Post
  • Last Post
  • Last Post
  • Last Post
