Homework Help: Two Forces
  1. Sep 17, 2008 #1
    The directions of two forces [tex]\vec{F_{1}}[/tex] and [tex]\vec{F_{2}}[/tex] (with F1 > F2) that are exerted at a point from angle of 150 degrees between them. Find the relations that must exist between the magnitudes of these forces [tex]\vec{F_{1}}[/tex] and [tex]\vec{F_{2}}[/tex] so that the net force has a magnitude equal to that of [tex]\vec{F_{1}}[/tex] .
    2. Relevant equations
    [tex]\sum\vec{F}=0[/tex]
    3. The attempt at a solution
    none so far.
    Need help getting started..
    [tex]\vec{F_{1}}[/tex] = [tex]\vec{F_{1}}[/tex] + [tex]\vec{F_{2}}[/tex] I think this is what the problem is stating, but wouldn't that mean F2 = 0?
  3. Sep 18, 2008 #2
    Start out by setting up a coordinate system to place the vectors in so you can analyze them in terms of components. To simplify things, try directing F1 along the positive x axis.
    To find the net force vector just add the components. Use the pythagorean theorem to find the magnitude of the net force vector. You want the magnitude of that force to equal the magnitude F1.
    The only "problem" I seem to run into with this question is that I'm not sure the inequality you introduced in the problem statement is a constraint that must always be satisfied. If that is the case, there is only one answer and your guess is correct, but not for the reasons I think you are thinking.
