Friction: Exploring Static vs. Kinetic & Its Impact on Energy Conservation
  • Thread starter nivek114
  • Tags
    Friction
In summary, static friction is used for a rolling object because the bottom of the wheel is not sliding across the surface. Additionally, kinetic friction converts kinetic energy into heat energy, while static friction does not, which is why the effects of friction are not ignored in the conservation of energy.
nivek114
1. Why do we use static friction instead of kinetic friction for a rolling object?
2. Why do we ignore the effects of friction in the conservation of energy?
Because, even though a rolling object is moving, it isn't sliding across the surface.
We don't. Friction turns kinetic energy into heat energy.
Need me to clarify or give examples of either answer?
1. The bottom of the wheel is not moving with respect to the ground at contact.
2. Since bottom of the wheel is not moving, the force does not move through a distance.
Right, I should clarify my second answer. Kinetic friction turns kinetic energy into heat energy. Static friction does not. sorry.
What is friction?
Friction is a force that resists the relative motion of two surfaces in contact with each other. It is caused by the irregularities in the surfaces of objects that come into contact with each other.
How is friction measured?
Friction is measured using a unit called coefficient of friction. It is a dimensionless number that represents the ratio of the force required to move an object across a surface to the force pressing the two surfaces together.
What factors affect friction?
The amount of friction between two surfaces is affected by the nature of the surfaces, the force pressing them together, and the presence of any lubricants or contaminants. Rough surfaces have higher friction than smooth surfaces, and increasing the force pressing the surfaces together increases the amount of friction.
How does friction affect motion?
Friction can either help or hinder motion. When trying to move an object, friction acts in the opposite direction and makes it harder to move. However, friction also helps us walk, drive, and grip objects by providing traction.
How can friction be reduced?
Friction can be reduced by using lubricants like oil or grease between surfaces, making surfaces smoother, or by reducing the force pressing the surfaces together.
