cgone
- 3
Hi all,
So I have these two parachute problems that have been giving me problems any aid you can provide would be much apreciated!
A)A probe is to land on the surface of Mars and I am required to find out the diameter of the parachute.
Given constance:
m=40kg
g=3.75m/s2
v0=100m/s
vf= 3m/s
x0=100m
Pair=2/3*1.1774
Cd=1.4
A=pi*D2/4 (where D is the unknown diameter of the parachute)
m[tex]\frac{dV}{dt}[/tex]=mg-[tex]\frac{1}{2}[/tex]Pair*Cd*AV2
I've seprated the variables and simplified to get:
g-[tex]\frac{k}{m}[/tex]*V2*dV=dt
where k=[tex]\frac{1}{2}[/tex]PairCdA
[tex]\sqrt{}[/tex]
So i decomposed the function for integration:
[tex]\int[/tex][tex]\frac{\frac{1}{\sqrt{g}}}{\sqrt{g-\sqrt{\frac{k}{m}}V}}[/tex]+[tex]\frac{\frac{1}{\sqrt{g}}}{\sqrt{g+\sqrt{\frac{k}{m}}V}}[/tex]
(ignore the second square root on top of the K/m that comes from G, it's only supposed to be on g)
and so that I've integrated to get the following:
[tex]\frac{1}{\sqrt{g}*\sqrt{\frac{k}{m}}}(Ln(\sqrt{g}-\sqrt{\frac{k}{m}}V))+Ln(\sqrt{g}-\sqrt{\frac{k}{m}}V))=t+c[/tex]
At this point I understand that I can raise everything to E and cancel the +-[tex]\sqrt{\frac{k}{m}}V[/tex] but from here I am unsure (also not 100% on the integration)
Also, I have a similar problem however it's not falling, rather slowing down from a parachute (rocket car slowing down from parachute), where I need to find the distance required to stop the car.
Where I was given m[tex]\frac{dV}{dt}[/tex]=-[tex]\frac{1}{2}[/tex]Pair*Cd*AV2
So I integrated as a seperable (don't think this is the right way though) to get
[tex]\frac{-1}{kV}=t+c[/tex] (a check or direction for this one is all I need)
Thank you!
Given constance:
m=40kg
g=3.75m/s2
v0=100m/s
vf= 3m/s
x0=100m
Pair=2/3*1.1774
Cd=1.4
[tex]\sqrt{}[/tex]
Thank you!
