Homework Help: Two Questions:
  1. Feb 19, 2005 #1
    1. Why do tires grip the road better on level ground than they do going uphill or downhill?
    I have some ideas, but I'm not sure how to word them, or if they are correct. Any suggestions would be appreciated.
    2. A mass M(1) = 3.5 kg, rests on a horizontal table and is attached by ropes to masses M(2) = 1.5 kg and M(3) = 2.5 kg. After is is released, what are the magnitude and direction of the acceleration of M(1)? Ignore friction.
    Answer: I calculated 1.14 m/s^2 to the right. The answer is known to be between 1-2. If anyone can confirm my calculation it would be appreciated.
    ~Thanks.
  3. Feb 19, 2005 #2
    Andrew Mason
    The 'grip' depends on the normal force which is opposite to the component of gravity perpendicular to the road. When the vehicle is inclined by an angle [itex]\theta[/itex] from the horizontal, the normal force changes by a factor of [itex]cos\theta[/itex].
    I gather that M(1) hangs down off the table to the left and M(3) hangs down on the right and there is some kind of pulley with each (you should provide all the details).
    I get a different answer. Why don't you show what you did.
    AM
  4. Feb 20, 2005 #3
    For question two I did the following:
    Object 1:
    Fnety = 0
    Fnetx = T = M(1)a
    Object 2:
    T- W(2) = -M(2)a
    T = W(2) - M(2)a
    T = M(1)a
    M(1)a = W(2) - M(2)a
    a = M(2)g % M(1) + M(2)
    Then I substituted in #'s and repeated the procedure for M(3). I took the result from the left acceleration and subtracted it from the larger right acceleration.
  5. Feb 20, 2005 #4
    Andrew Mason
    What is W(2)? Weight? Why is it important?
    What is %? This makes no sense at all to me.
    Since the accelerations of all three masses are equal just treat all three masses as one mass. Then use the fact that the net force is (M3 - M1)g. It is that simple.
    AM
  6. Feb 20, 2005 #5
    W(2) = The weight of object two. The Fnet of object two is determined by -M(2)a because it is going down. The % is being used as division.
    How can you make the masses equal when M(1) is ona table and the other masses are hanging from it. The higher weight of mass 3 is what pulls M(1) to the right, but M(2) has an acceleration which slows the acceleration to the right.
  7. Feb 20, 2005 #6
    Andrew Mason
    It is the difference in the weight of M3 and M1 that provides the acceleration to the system.
    [tex](M_1 + M_2 + M_3)a = M_3g - M_1g[/tex]
    [tex]a = g\frac{M_3 - M_1}{M_1 + M_2 + M_3} = 9.8 * \frac{1}{7.5} = 1.31 m/s^2[/tex]
    AM
  8. Feb 21, 2005 #7
    Ok, I've got it now. Thanks!
