Two spaces are not homeomorphic
  1. Jun 3, 2010 #1
    Prove that no continuous surjective function [itex]f : ]0; 1] \rightarrow R [/itex]can be injective.
    My questions is can I use a proof by contradiction and assume that there is a injection
    Then I can use the fact that if there was an injection ie theres a bijective function then the two spaces would be homeomorphic to each other.
    And then show the the two spaces are not homeomorphic so impossible?
  3. Jun 3, 2010 #2
    Re: Homeomorphism
    If there's a bijection, they would be isomorphic as far as I can tell. I think that it has something to do with the continuity and that the segment is closed.
  4. Jun 3, 2010 #3
    quasar987
    Re: Homeomorphism
    Of course.
  5. Jun 3, 2010 #4
    lavinia
    2017 Award
    Re: Homeomorphism
    the inverse image of the positive integers has a limit point
  6. Jun 3, 2010 #5
    Re: Homeomorphism
    Then I will try and show that both spaces are homeomorhic.
  7. Jun 3, 2010 #6
    Re: Homeomorphism
    Suppose that f is continuous and injective. Maybe it's easiest to prove that it cannot be a surjection, i.e. there is at least one real number which is not the image of any point on the segment [0, 1].
  8. Jun 3, 2010 #7
    Re: Homeomorphism
    But the segment is (0.1]
  9. Jun 3, 2010 #8
    Re: Homeomorphism
    You only need one boundary point contained in the finite region, so i think you can still do it.
  10. Jun 3, 2010 #9
    Re: Homeomorphism
    So If I assume that f is continuous and injective:
    take
    [itex] a \in X a = 1 [/itex]such that [itex]f(a) \in Y[/itex]
    And as [itex]f[/itex]is continuous and injective I can find for any [itex]\epsilon > 0[/itex]
    a real element [itex] y \in Y [/itex] such that the inverse [itex]f^{-1}(y+ \epsilon) - f^{-1}(y) + f^{-1}(y) - f^{-1}(y-\epsilon)[/itex] is in [itex]X[/itex]
    How ever since [itex]f^{-1}f(a)[/itex] is a boundary point this is impossible
    showing there is at leat one real number which is not the image of any point on the segment (0, 1].
  11. Jun 4, 2010 #10
    quasar987
    Re: Homeomorphism
    I'm sorry, I read your post a little too fast. Your second sentence contains a false statement: the existence of a continuous bijective function does not imply the existence of a homeomorphism.
    To solve this problem, try supposing that there is a continuous injective and surjective function f:]0,1]-->R. Then f([½,1])=[a,b] for some real numbers a and b. Suppose that f(1)=b (the case f(1)=a is similar). Show that no x>b is hit by f. In other words, [itex]f^{-1}(]b,\infty[)=\emptyset[/itex] and thus f is not surjective: a contradiction.
  12. Jun 4, 2010 #11
    Re: Homeomorphism
    I appreciate all your help guys.
  13. Jun 5, 2010 #12
    Re: Homeomorphism
    Your map can't exist in the first place; the image of a compact subset under a continuous map is compact, and the reals are not compact.
    Other than that, I suppose you could also say that if your map was injective, then since bijective maps from compact spaces to Hausdorff spaces are homeomorphisms, then you would have a contradiction since [0,1] is not homeomorphic to the reals, since for example [0,1] is compact; although this is the point I made in the first paragraph.
  14. Jun 6, 2010 #13
    Re: Homeomorphism
    Prove it.
  15. Jun 6, 2010 #14
    Office_Shredder
    Staff Emeritus
    Re: Homeomorphism
    The domain isn't compact anyway (it doesn't contain 0). As for proving the reals are NOT compact, that's easy since all you need to do is come up with a counterexample to the definition.
    quasar has the right idea.... basically, for there to be a continuous bijection it has to be monotone (increasing or decreasing). Then f(1) taking a finite value causes serious problems
  16. Jun 6, 2010 #15
    Landau
    Re: Homeomorphism
    A subset of R^n is compact iff it is closed and bounded. ]0,1] is not compact because it is not closed. R is not compact because it is not bounded.
  17. Jun 7, 2010 #16
    lavinia
    2017 Award
    Re: Homeomorphism
    the negative integers -m map to an infinite decreasing or increasing sequence in (0,1] that either has a limit point or converges to 0. If there is a limit point the inverse can not be a homeomorphism. but then the positive integers must have a limit point.
  18. Jun 14, 2010 #17
    Re: Homeomorphism
    Maybe you can use the fact that a continuous bijection between [0,1] and R
    would be (is) a homeo. (cont. bijection, compact, Hausd. , yada yada)
    Then, if h is that homeo., the restriction:
    h<sup>^</sup>:(0,1]-->R-{f(0)} is also a homeo.
    but R-{f(0)} is disconnected, and (0,1] (as a subspace) is not.
  19. Jun 14, 2010 #18
    quasar987
    Re: Homeomorphism
    This looks like an argument against the existence of a homeomorphism between R and [0,1] (which is direct by compactness by the way). The OP was trying to find an argument against the existence of a homeo between R and (0,1].
  20. Jun 14, 2010 #19
    Re: Homeomorphism
    I was not claiming this is a solution; just mentioning
    a result that seemed closed to what the OP was asking
    for; I thought it may help give him an idea.
  21. Jun 19, 2010 #20
    Re: Homeomorphism
    Sorry, I thought that the ]0,1] was a typo to mean [0,1], in which case I'd obviously have been correct. I've never seen this (very weird) notation, and would use (0,1].
    Looking at it though, it does make a bit of sense, its like the brackets are indicating visually where the boundaries lie on the real line, and it can be annoying having things like (0,1) around when there are also 2-tuples.
  22. Jun 19, 2010 #21
    quasar987
    Re: Homeomorphism
    The notation is universal in french books. I've seen it on rare occasions in english books, perhaps by authors trying to popularize it.
  23. Jun 19, 2010 #22
    Re: Homeomorphism
    Since f is continuous, the preimage [tex]A = f^{-1}((f(1), +\infty))[/tex] must be open in (0, 1]. Ditto for [tex]B = f^{-1}((-\infty, f(1))[/tex].
    Then [tex](0, 1) \subset A \cup B [/tex] and the surjectivity assures neither A nor B are empty. And this along with their openness implies [tex]A \cap B \ne \emptyset[/tex], which implies [tex]A \cup B[/tex] is connected, and so [tex]f(A \cup B)[/tex] is connected (and equal the whole real line), and therefore [tex]f(1) \in f(A \cup B)[/tex]. So f is not injective.
