When Do Two Stones Meet in the Air?
  • Thread starter Matthematic
  • Tags
    stones
In summary, the problem involves two stones being thrown up with the same initial velocity, and the question asks for the height at which they meet. The solution involves setting up equations for each stone and solving for the time at which they meet. The correct answer is 1.84 meters, but the student has consistently been told it is wrong. They have tried using different formulas and approaches, but have not been able to find the error in their calculations. They plan on seeking the solution from the professor or another student who got it right.
Matthematic
Suppose you throw a stone straight up with an initial velocity of 20.5 m/s and, 4.0 s later you throw a second stone straight up with the same initial velocity. The first stone going down will meet the second stone going up. At what height above the point of release do the two stones meet?
xf = xi + vit + (at2)/(2)
So far I have setup an equation for each stone involving 't' and set them equal to find the time the stone meets in the air, and then attempted to solve for the height of either stone at time 't'. My answer in consistently 1.84 meters. I keep getting told this is the wrong answer.
So far I have this
vt-gt^2 = v(t-4) - g(t-4)^2
simplified to:
t = (v/g) + 2
Plug in numbers to get:
t = 4.0918;
plug 't' into the position function for stone 1:
height = 20.5(4.0918)-9.8(4.0918^2) = 1.84 meters.
I'm not sure what's going on, I have also tried using (t+4) for tone #2, but the problem still turns out to be wrong.
So far I have this
simplified to:
t = (v/g) + 2
t = 4.0918;
I'm not sure what's going on, I have also tried using (t+4) for time #2, but the problem still turns out to be wrong.
(Fixed some typos in Edit.)
Hello Matthematic. Welcome to PF !
Thanks for using the template correctly.
Why would you use t + 4 for anything?
Show some steps in going from
vt - (g/2)t2 = v(t-4) - (g/2)(t-4)2
to
t = (v/g) + 2​
To quickly check your answer, plug the value of t that you get into each side of
to verify that the result makes sense.
Math fun
I thought maybe my mistake was that I should calculate as t=0 for first stone, and t=4 for the second stone (t and t+4). I thought wrong.
Code:
vt-gt[SUP]2[/SUP] = v(t-4) - g(t-4)[SUP]2[/SUP]
to
Code:
t = (v/g) + 2
vt+(-[itex]\frac{g}{2}[/itex])t2=v(t-4)+(-g)(t-4)2
vt - [itex]\frac{g}{2}[/itex]t2=vt - 4v - [itex]\frac{g}{2}[/itex]t2 + 4gt - 8g //expand and distribute.
0 = -4v + 4gt -8g // cancel out terms that exists on both sides.
4v + 8g = 4gt // Move terms over to the other size to isolate the 't'
[itex]\frac{v}{g}[/itex] + 2 = t // divide by 4g.
Put in 20.5 s 'v' and 9.8 as 'g'
t = 4.0918
Now use 't' in the position function to determine what height the stones are at at the time that they are the same height.
s(t) = 20.5(4.0918) - [itex]\frac{9.8}{2}[/itex](4.09182) = 1.8413 meters. (wrong answer)
At the time of my writing this, I had a thought. Is that function above the velocity function or the position function? I thought it was the position function. Perhaps my error is that I should integrate the function and then plug in t? I'm not to sure, I only have one more try or I get marked wrong for the problem.
t = 4.0918
Everything looks fine.
Do you get the same answer plugging into
v(t-4) - (g/2)(t-4)2 ?​
Alternative formulae
Yes.
Update:
Using
vf = vi +at2
and
d = ((vi + vf)/2) *t
I have calculated displacement again getting the same answer.
Edit: I think its time to move on. When I get the solution from the professor or a student who got it right, ill post it here for any future googlers who find this tragic story.
Could it be as simple as you having to use g = 9.81 m/s2 and then getting something like 1.80 m ?
In which case you've done everything right, but different from what's in the answer book... c.q. the poor computer.
Matthematic said:
Yes.
Update:
Using
vf = vi +at2
and
How do you know it's the wrong answer.
If this is graded by some website homework service, or the like, it may be as simple as a problem of an incorrect number of significant digits.
My professor is doing me a favor because I turned it in early, he said I can still try one more time to get it right. Ill try the more accurate gravity constant. But ill make sure to figure out what went wrong and post it.
I made a guess based on the sig-figs of the other numbers and used 1.80 (instead of 1.84) and I got it right. This is going to be a long semester if more stuff like this happens.
No big deal: you did the right things, only used 9.8 instead of 9.81. Semesters look a lot shorter once you gather some experience with them :smile:
What is the significance of two stones having a meeting?
The concept of "two stones having a meeting" is often used as a metaphor for a situation where two seemingly inanimate objects are interacting or communicating with each other. It can also represent a moment of reflection or exchange of ideas between two individuals.
What can we learn from two stones having a meeting?
The idea of two stones having a meeting can teach us about the importance of communication and interaction in any relationship, whether it be between objects or people. It also reminds us that even the smallest or most unlikely of things can have a meaningful connection.
Can two stones really have a meeting?
While it may seem far-fetched, the concept of "two stones having a meeting" is not meant to be taken literally. It is simply a way to symbolize the idea of interaction and communication between two entities, whether they are living beings or inanimate objects.
What other scenarios can be represented by two stones having a meeting?
The metaphor of two stones having a meeting can be applied to a variety of situations, such as a peaceful discussion between two opposing sides, a meeting of minds between two brilliant individuals, or even a moment of self-reflection and introspection.
How can we use the concept of two stones having a meeting in our daily lives?
The idea of "two stones having a meeting" can remind us to always be open to communication and exchange of ideas with others. It can also encourage us to look for connections and common ground with people or things that may seem different from ourselves. Ultimately, it can inspire us to foster meaningful relationships and collaborations in our personal and professional lives.
10K
