Homework Help: Two Thin Lenses
  1. Apr 25, 2010 #1
    An optical system consists of two identical lenses; the focal length of each lens is fo (where fo) is positive). The lenses are separted by a distance d. Denote the focal lenths of the lens assembly by f and f'.
    a) Show that for any separation of the lenses f = f'
    b) Find the separation between lenses that leads to the focal length of the lens assembly being equal to 2fo
    2. Relevant equations
    thin lens equations, refracting/travelling matrices?, f' = -1/a21
    3. The attempt at a solution
    a) I did the intuitive approach: a set of rays coming from either end of the 2 lense assembly will experience the same assembly, and hence converge to the same focal lengths (after exiting assembly at either end)
    b) I used the matrix method with the matrix for thin lense being (1, 0; -1/fo, 1)
    anyways, after some calculation... I got: d = (3/2)fo (correct?)
  3. Apr 25, 2010 #2
    Not sure about the matrices but you could also use the formula for the focal length of compound lenses:
    [tex]\frac{1}{f}=\frac{1}{f_1}+\frac{1}{f_2}-\frac{d}{f_1 f_2}[/tex]
    That will get you the same answer that you got for (b), so both methods get you the same answer. So I'd say (b) looks correct.
