Two thin rods on the x-axis
  • Thread starter acedeno
Two thin rods of length L lie along the x-axis, one between x = a and x = a + L, and the other between
x = –a and x = –a – L. Each rod has positive charge Q distributed uniformly along its length.
a. Calculate the electric field as a function of x produced by the rod on the left hand side
(from –a – L to –a) at points along the positive x-axis.
b. Determine the magnitude of the force that one rod exerts on the other.
E=∫[dq/4πε_naught*r^2] where dq=λdx for a line of charge
Well since for part a, they only want the electric field in the positive x-axis I came up with:
E=∫from -a to -a-L of [λdx/4πε_naught*(-a-L+x)^2
giving me:
E=L/2a+L(2a+2L) when the integral is evaluated from -a to -a-L. - I'm aware I need to multiply my constants back in but for right now, I'm just worried about the integral.
Am I on the right track?
Answers and Replies
SammyS
Staff Emeritus
1,012
bump
Please read and follow the rules of these Forums. Wait 24 hours before bumping.
Regarding your integral: E=∫from -a to -a-L of [λdx/4πε_naught*(-a-L+x)^2 ,
What does x represent?
You seem to have used x for two different things in the same expression.
x is suppose to represent where you are on the x axis.
-regarding the bump, sorry it won't happen again.
SammyS
Staff Emeritus
1,012
But you have (λ dx) in the integral, so in that sense, you're using x as the integration variable.
Use something like x0 (or some variable like u or s), for the place at which you are finding E. You then need to express the distance from x0 to the point x on the rod, over which you are integrating. --- r = x0 - x .
Sorry, I'm not following. The way I see it, when you take all the constants out you are just integrating dx/(-a-L+x)^2
SammyS
Staff Emeritus
1,012
Yes, but that's not what you should be integrating.
(-a-L+x) is the distance between point x, and point (a + L) on the x axis.
What would the integral be if you were finding E at a fixed location, such as at x = 1.357 meter, on the x-axis ?
Okay, I think I know what you mean.
E=∫kdq/r^2 let dq=λdl and r =(a+x), the distance from the end of the rod to a +x value
E=λk/(a+x)^2∫dl -integrating from -a-L to -a
E=λk/(a+x)^2[(-a)-(-a-L)]
E=λkL/(a+x)^2
How's that look?
edit: I decided to use k rather than 1 over 4pi epsilon naught
SammyS
Staff Emeritus
1,012
No. r should be the distance between the element of charge, dq, and x. So, r = x - l.
Related Threads on Two thin rods on the x-axis
  • Last Post
  • Last Post
11K
  • Last Post
  • Last Post
  • Last Post
  • Last Post
