Homework Help: Two undetermined constants
  1. Oct 4, 2009 #1
    If s(0) = 0, v(1) = 24 and a(t) = 24t+6 find s(t)
    2. Relevant equations
    3. The attempt at a solution
    I know a(t) is s''(t) and v(t) is s'(t). however, How can I find s(t)?
  3. Oct 4, 2009 #2
    Dick
    Re: anti-derivative?
    Integrate a(t) twice. You get two undetermined constants. Find them by using the s(0) and v(1) conditions.
  4. Oct 4, 2009 #3
    We have not learnt integration yet :(. Infact, we have not even done anything from finding a function from it's derivatives.
    Is there any other way to do it?
  5. Oct 4, 2009 #4
    PAR
    Have you been given any equation relating s,v, and a?
  6. Oct 4, 2009 #5
    Nothing at all.
  7. Oct 4, 2009 #6
    Find the anti-derivative of a(t), which is v(t).
    Plug in t=1 for v(t) to get the constant.
    The find the anti-derivative of v(t), which is s(t).
    Plug in t=0 for s(t) to get the constant, and now you have your answer.
  8. Oct 4, 2009 #7
    What is this anti-derivative? What's integration? :/
  9. Oct 4, 2009 #8
    PAR
    Well either you haven't been paying attention in class or there is something seriously wrong with how they are teaching you.
    Since you haven't learned integration, the only possible way I can see you finding s(t) by derivatives only is knowing that since a(t) = 24t + 6, all of the integrals of a(t) must obey the power rule. Knowing this you know that
    v(t) = f(t^2) and s = g(t^3)
    So g(t^3) is a cubic. and can be written in the form:
    q*t^3 + b*t^2 + c*t + d
    can you solve from there?
  10. Oct 4, 2009 #9
    Could you not do the inverse of the power rule?
  11. Oct 4, 2009 #10
    PAR
    The inverse of the power rule is integration. Since you know that
    s = q*t^3 + b*t^2 + c*t + d
    all you need to do is solve for q, b,c and d using derivatives.
  12. Oct 4, 2009 #11
    then s = 3qt^2 + 2bt + c?
  13. Oct 4, 2009 #12
    PAR
    no, s = q*t^3 + b*t^2 + c*t + d
  14. Oct 4, 2009 #13
    I'm so lost right now.
    My teacher shall get angry letters >:[
  15. Oct 4, 2009 #14
    PAR
    Recap: You know that s(t) is a cubic because when you take two derivatives of a cubic you get At + B which is the same form as a(t) = 24t + 6.
    So using the initial conditions eg. s(0) = 0, the a(t) formula, s(t) = q*t^3 + b*t^2 + c*t + d, and knowing that s' = v and s'' = a, solve for q,b,c, and d.
  16. Oct 4, 2009 #15
    Someone's been skipping class. Anti-derivative is basically doing the reverse of a derivative.
    For example the derivative of 3x^2 + 5x + 4
    = 6x + 5
    The anti-derivative of 6x + 5
    = 6x^2 * (1/2) + 5x * (1/1) + C
    = 3x^2 + 5x + C
    If the f(x) = 3x^2 + 5x + C
    and we're given f(0)=4
    then we can figure out the constant C
    and we get f(x) = 3x^2 + 5x + 4
    Hey guys, what's math? :p
  17. Oct 4, 2009 #16
    I think I got it! My book doesn't even have this stuff in it. No, I was not skipping class. This teacher just gives us questions we've not even seen before. He does it all the time.
    v(t) = 12t^2+6t
    s(t) = 4t^3+3t^2 + t?
    no?
    not even close?
  18. Oct 4, 2009 #17
    PAR
    almost, v(t) is incorrect, redo the derivative of s(t) to find the correct v(t)
  19. Oct 5, 2009 #18
    am i missing the constant in the v(t)? a K right?
  20. Oct 5, 2009 #19
    PAR
    Your s(t) is correct, now take its derivative to find v(t).
    yes, you are missing a constant in v(t)
    EDIT: Sorry I said that your s(t) is correct, sorry it isn't, the "t" term is wrong, you need a constant coefficient, so you need a Kt not a t. But using the initial conditions given to you, you can find what K is.
  21. Oct 5, 2009 #20
    You need the constant, so it's
    v(t) = 12t^2+6t+C
    to find C, you plug in the fact that you know v(1)=24
    After you find C, then you repeat the process to find s(t)
  22. Oct 5, 2009 #21
    See, this is what I don't understand.
    would I just write 24 = 12t^2+6t +c?
    the solve for c? where does the K come from?
  23. Oct 5, 2009 #22
    v(t) = 12t^2+6t + C
    s(t) = 4t^3+3t^2 + Kt +C
  24. Oct 5, 2009 #23
    If I'm understanding your use of variables correctly, K is C.
    K is one of the coefficients in s(t), which is known by figuring out C in v(t).
    v(t) = ....... + C
    s(t) = ...... + Kt + ........
    You wrote v(t) correctly, now just plug in t=1, and you'll get C.
  25. Oct 5, 2009 #24
    yes, but C is not the same value or variable in both of those equations. C is just commonly used to represent an unknown constant.
    The C in your first equation will be the K in your 2nd equation.
  26. Oct 5, 2009 #25
    Why do I get 2 values for C, though?
