Homework Help: Typing formula in excel
  1. Jun 1, 2009 #1
    I have the formula
    S=t^(-1/b)*g
    I want to type this into excel.
    2. Relevant equations
    3. The attempt at a solution
    For S are values typed into the second column (B)
    for t are values typed into column A.
    I 'named' the b and g using the name manager and set the initial values as 1.
    then in the column C i want the predicted values for S so to get the first predicted value, i typed:
    =g*(A2^(-1/b))
    but i kept getting the #VALUE error and i dont know whats wrong with =g*(A2^(-1/b))
    Thank you
  3. Jun 1, 2009 #2
    Redbelly98
    Staff Emeritus
    That #VALUE can happen when one of the "numbers" is actually text.
    A few things to look at are:
    What is the value in cell A2?
    And, what is the result when you type these formulas:
    =g
    =b​
  4. Jun 1, 2009 #3
    MATLABdude
    It can also happen when the cell isn't wide enough to display the resultant value.
  5. Jun 1, 2009 #4
    sylas
    That gives #####, not #VALUE.
  6. Jun 1, 2009 #5
    MATLABdude
    Ah, correct you are. However, I was unaware that you could assign values like that in Excel. Whenever I've done that, it's been hardcoded values, or using a locked reference like $A$5 for a value in cell A5 which you don't want automatically incremented by Excel.
    EDIT: I think that might be why the OP's thing isn't working: they're trying to assign a value to b somewhere along the line, and then using the letter b in their calculations.
  7. Jun 1, 2009 #6
    Redbelly98
    Staff Emeritus
    But doing that IS possible in Excel, it just has to be done properly.
    Check out Insert-Name-Define for how to assign a cell's value to a variable name.
  8. Jun 2, 2009 #7
    The value in A" (first value in that column) is 138.
    I used the 'name manager' to define g and b.
    I defined them then in A10 i put b and in B10 i put 1
    then in A11 i put g and in B11 i put 1
    (I put 1 because i needed to initialize the b and g) is this wrong?
    I used the idea from the website:
    http://www.csupomona.edu/~seskandari/documents/Curve_Fitting_William_Lee.pdf [Broken]
    see pages 6 and 7.
    then i typed =g*(A2^(-1/b)) and this gave a #VALUE error.
    But i dont know why?
  9. Jun 2, 2009 #8
    sylas
    Well, you are not getting #NAME? errors, so you must have defined g and b to be something.
    Make sure g and b are defined to be absolute references (with dollar signs) in the name manager. That's the default. Somehow you are using things that are not numbers.
    Here's what I think you are trying to do:
    Cheers -- sylas
  10. Jun 2, 2009 #9
    ok, thanks.
    On the excel vista where's the 'solver' tool? i cant seem to find it since it's different to the windows xp.
    thanks
  11. Jun 2, 2009 #10
    Redbelly98
    Staff Emeritus
    Have you installed the Solver add-in? Just having Excel does not necessarily mean you have Solver.
    Click on Tools, then Add-Ins. Is the box checked for "Solver"?
  12. Jun 2, 2009 #11
    but on my excel, there isnt a 'tools' section. there's just:
    home, insert, page layout, formulas, data, review, view.
    where can i find the add-ins?
    thank you
  13. Jun 2, 2009 #12
    Redbelly98
    Staff Emeritus
    I see. You have Excel 2007, and I have Excel 2003. Things are laid out a lot differently.
    Here are instructions for installing Solver:
    http://office.microsoft.com/en-us/excel/HP100215701033.aspx [Broken]
    If you get to the part where the Solver box is already checked, that means you already should have it.
  14. Jun 2, 2009 #13
    Redbelly98
    Staff Emeritus
  15. Jun 2, 2009 #14
    Thank you.
    I installed it just now.
    (I didnt have it before)
