Uart and data rate
  1. Dec 10, 2006 #1
    Let's say you have a 8-bit and 32-bit uart (universal asynchr. receiver/transmitter), which one of them would you say would be more tolerant to the differences in the bata bit rate? in general...
  3. Dec 10, 2006 #2
    chroot
    Staff Emeritus
    I don't know what you mean by an 8-bit UART.. UARTs are serial transceivers.
    - Warren
  4. Dec 10, 2006 #3
    By 8-bit I mean that data byte is 8 bits, by 32 --- data "unit" is 32 bits.
    I think it's an issue of when to sample, since the clock is much faster than the data line.
  5. Dec 10, 2006 #4
    chroot
    Staff Emeritus
    I don't see how the data width has anything to do with "tolerance" to the data rate.
    I suppose you could argue that if the serial data rate slowed down by, say, 1 us per bit, an 8-bit word would only be "slowed down" by 8 us, while a 32-bit word would be "slowed down" by 32 us.
    - Warren
  6. Dec 10, 2006 #5
    ok, maybe a bad exam question.... it was applied specifically to the transmitter, which did not make sense to me, that's why i asked ... thanks anyway ...
  7. Dec 11, 2006 #6
    NoTime
    I don't know about the current generations, but UARTs used to come with a 1, 2 or 4 word receive data buffer.
    Nit picking aside they were referred to as 8, 16 and 32 bit UARTs.
    The 32 bit UART was more tolerant of interrupt timing when the stored data was transferred to system memory.
    Perhaps the question referred to this.
  8. Dec 12, 2006 #7
    Here is what I got after reading some various stuff on the internet....
    UART timing is synchronized only to the start bit of the incoming data, so if the data is a bit too fast or too slow, UART might end up sampling on the data bit transitions, so actually 32 bit UART is less tolerant.
  9. Dec 12, 2006 #8
    chroot
    Staff Emeritus
    But... doesn't every byte have its own start bit, even in a "32-bit" UART?
    - Warren
  10. Dec 12, 2006 #9
    berkeman
    Staff: Mentor
    Yeah, 7- 8- (and 9-) bit frames are the only ones I'm aware of.
    http://en.wikipedia.org/wiki/RS-232
    I'm still confused by the OP's mention of 32-bit UARTs. All that I can think of is that he means the outside parallel interface to the UART -- different bus widths for different memory configurations and uCs. But I think you're correct, that the actual frames (start bit, stop bit, parity, etc.) are confined to basically one byte of data +/- 1 bit.
  11. Dec 12, 2006 #10
    chroot
    Staff Emeritus
    Those were my thoughts, berkeman -- that the "32-bit" moniker only refers to its external parallel interface -- and thus that it has no bearing at all on its tolerance to serial timing issues.
    - Warren
  12. Dec 12, 2006 #11
    ok, sorry if I confused anybody... in lab we did program an 8-bit UART. And this whole deal with 32 bit frame is a theoretical question that was intended to test our conceptual understanding of the UART and the fact that if we sample too soon or too early it has affect on the sampling of the following bits, i.e. one may land in the transition between bits rather than in the middle of the bit.
  13. Dec 12, 2006 #12
    chroot
    Staff Emeritus
    So, is it a trick question?
    - Warren
  14. Dec 12, 2006 #13
    yah... prof's "trick" question :rolleyes:
    and seems like 32-bit UARTs don't even exist based on what you guys say...
