What are some possible uncertainties for mass measurements in a physics lab?
In summary, the lab used an atwood machine to test Newton's second law. The data graphed shows that the masses do not have any uncertainty associated with them. However, the lab was told to make up an uncertainty, which they did by using the last nonfluctuating digit on the measuring apparatus.
L²Cc
149
For a physics lab, we had to test Newton's second law using an atwood machine. Now, as I'm graphing my data, I realized I don't have any uncertainty for the masses. I have been told to make up an uncertainty, yet my uncertainty has to make sense, and I should have a reason. For case one, my masses are as follows:
M m
100 100
110 90
120 40
130 70
140 60
150 50
? Any ideas?
There's no need to make up the uncertainty, just use the last nonfluctuating digit on the measuring apparatus. That is, if your scale gives you masses out to 0.01 kg, but the last digit drifts (assuming an electronic scale) and the one before it doesn't, then you know the mass +/- 0.1 kg. This is assuming that your scale has been calibrated, of course.
I think you didn't realize that a Mentor was moving your misplaced post from the general forums to here in the homework forums. I deleted the duplicate post that you put here mistakenly while this original post was being moved.
You need to show a little more work in order for us to help you. What are your ideas and thoughts so far?
How were the mass values determined? Did you weigh them, or did they come with some mass value stamped on them? If you weighed them, your scale will have some uncertainty associated with it (either in its datasheet, or its calibration data, etc.). If the masses came with values stamped on them, check their supplier datasheets for their tolerances.
Ok thank you. Firstly, we were not given an electronic balance. They came with the mass value stamped on them. That is the only information we were given. What do you believe would be a reasonable uncertainty for the masses. I was thinking 0.01 kg since the lightest weight increment on my data table "weighs" 0.1. Or, we can find the greatest deviation and divide by 1000 to convert into kilograms. Hence, we would end up with an absolute uncertainty of 0.1 g for the masses ?
I googled beam balance masses tolerance, and got some useful hits. Check out the tolerances on these standard masses:
http://www.samyakinternational.com/ie_3_1.htm
So that gives you a number, and a reference that you can put into your report to support your assumption. Google can be a helpful tool if you can think of a good combination of keywords that has a good chance of intersecting in a useful set of page hits.
1. What is uncertainty?
Uncertainty refers to a lack of certainty or predictability about a situation or outcome. It can arise from a variety of factors, such as incomplete information, conflicting data, or the inherently unpredictable nature of certain phenomena.
2. Why is uncertainty important to understand?
Uncertainty is an unavoidable aspect of life and can have significant impacts on decision making, risk management, and overall well-being. Understanding and managing uncertainty can help individuals and organizations make more informed and effective choices.
3. How can uncertainty be quantified?
There are various methods for quantifying uncertainty, such as probability theory, statistical analysis, and mathematical modeling. These approaches involve assessing the likelihood of different outcomes and their potential consequences.
4. What are some common sources of uncertainty?
Uncertainty can stem from a variety of sources, including natural phenomena (e.g. weather patterns), human behavior (e.g. market fluctuations), and technological limitations (e.g. predicting complex systems). It can also arise from the limitations of our own knowledge and understanding.
5. Can uncertainty ever be eliminated?
No, uncertainty cannot be completely eliminated. While we can reduce uncertainty through data collection and analysis, there will always be some level of unpredictability in any situation. However, understanding and managing uncertainty can help us make more informed and calculated decisions.
