Homework Help: Uncertainty Questions
  1. Sep 22, 2007 #1
    These are my measurements:
    D1 = 5.381 +/- 0.001 cm
    D2 = 2.070 +/- 0.001 cm
    t = 0.304 +/- 0.005 cm
    m = 40.04 +/- 0.005 g
    I then calculated the uncertainties of D1 and D2 squared:
    D1^2 = 28.95 +/- 0.01 cm^2
    D2^2 = 4.285 +/- 0.004 cm^2
    D1^2 - D2^2 = 24.67 +/- 0.01 cm^2
    Up until there, I'm pretty sure everything is correct.
    Than I had to calculate the volume of the washer by using the equation:
    (pi x (D1^2 - D2^2) x t)/4
    And I basically got stuck there. I'm not sure how to calculate my uncertainties when multiplying by t and so on.
    I tried it out by first adding the uncertainties of Dtotal and t (when multiplied) by using this equation:
    Dtotal^2 x t +/- Dtotal^2 x t x (change in Dtotal/Dtotal + change in t/t)
    That gave me a volume of 5.9 +/- 0.1 cm^3... which I then used to calculate a density of 6.8 +/- 0.1 g/cm^3.
    Does this seem correct or what am I doing wrong? I also don't know how to express my answers while doing the calculations; as in, I have random numbers from subtracting my givens (while subtracting my uncertainties) that I don't end up using.
    I'm really confused.
  3. Sep 22, 2007 #2
    How do you plus or minus something? Dtotal^2 x t +/- Dtotal^2?
    Do you know how partial derivatives work? You want to use
    [tex] \left( \sum_{i=1}^n \left( \frac{\partial f}{\partial x_i} \Delta x_i \right)^2 \right)^{1/2}[/tex]
    where f is the function you are evaluating, in this case the volume, the x_i's are each variable (d1, d2, ...), and the delta xi's are the uncertainties in each variable.
  4. Sep 23, 2007 #3
    I'm confused how to even use that equation though!
  5. Sep 23, 2007 #4
    I figured it out using this website:
    http://www.rit.edu/~uphysics/uncertainties/Uncertaintiespart2.html#mixtures [Broken].
    Thanks.
  6. Sep 23, 2007 #5
    Okay, as long as you got it. They have the total differential a little bit below, I was posting the magnitude of it (because an error vector is worthless). I like taking the magnitude of the total differential because it comes directly from vector calculus, and always works.
Loading...
