Understand foam porosity
  1. Jun 3, 2015 #1
    This should be a pretty simple question but I can't find a straight answer in the literature. I want to simulate a 3D model of a metal foam by starting with an aluminum block and filling it with randomly placed spherical holes of constant volume. The foam should have a porosity of 20 ppi (pores per inch) and a volume ratio of 25% aluminum. How many pores should there be, and what are their sizes?
    2. Relevant equations
    20 pores per inch
    25% aluminum, 75% void by volume
    3. The attempt at a solution
    I'm not clear on precisely what "ppi" means. Does 20 ppi imply that a 1 inch cube of aluminum should contain 20^3 = 8000 pores? And that each pore should have a volume of 0.75/8000 = 0.00009375 in^3? This seems pretty obvious but I want to make sure before I proceed. Thank you for your help!
  3. Jun 5, 2015 #2
    CWatters
    Assume the pores are spherical. Work out what the radius of each pore would be. Can you put them on a 1/20" pitch/grid without them intersecting each other :-)
    I'm afraid I'm not familiar with packing theories.
  4. Jun 5, 2015 #3
    CWatters
    Google suggests Cubic Close packing can achieve 74% packing density but I'm not quite sure how you calculate the PPI in that configuration..
    http://mathworld.wolfram.com/SpherePacking.html
  5. Jun 5, 2015 #4
    The pores in a foam are allowed to overlap with each other. This isn't a sphere packing problem though. This is a question of the expected value of the volume these pores will occupy.
  6. Jun 5, 2015 #5
    NascentOxygen
    Staff: Mentor
    Yes, that is how I see it. As far as averages go, it should make no difference whether the pores are neatly arrayed in equi-spaced rows and columns, or randomly positioned. So, take the easy route, consider them all neatly arrayed in 3D ranks. :smile:
    Work out the radius each would have if it were spherical, and compare this dimension with their centre-to-centre spacing to see whether the model seems realistic for your application.
  7. Jun 6, 2015 #6
    CWatters
    If the pores overlap each other won't the volume ratio be incorrect. (eg some of the volume is double counted).
    PS I believe they do overlap.
  8. Jun 6, 2015 #7
    NascentOxygen
    Staff: Mentor
    Will the expected overlap be likely to alter the prescribed composition of 25% by more than ±1 sig fig?
  9. Jun 8, 2015 #8
    CWatters
    If I did the sums right the volume of a single pore after deducting the 6 overlaps is
    8.86 * 10^-5 cubic inches compared to
    9.38 * 10^-5 calculated by ignoring the overlap
    8.86 * 10^-5 * 8000 = 0.71
    eg 71% rather than the 75% requested.
Have something to add?
Draft saved Draft deleted
Similar Discussions: Understand foam porosity
  1. Shear Understanding (Replies: 6)
  2. RLC Understanding (Replies: 1)
Loading...
