Understanding Energy: Where Does Initial Energy Remain?
  • Thread starter BruceNakagawa
  • Tags
    Energy
In summary, energy cannot be created or destroyed but can be transformed. When an object falls towards Earth, its energy is converted into kinetic energy. Upon impact, this energy is then transferred to the dust particles on the ground, causing them to heat up. This heat eventually dissipates and spreads out, but remains as thermal energy.
BruceNakagawa
We are all told that energy keeps on transforming that energy can be neither created or destroyed, but there is something I cannot just comprehend.
Take a object, any object, falling towards Earth for example, it keeps on accelerating because Earth's gravity is pulling on it, that's the Objects energy at work, when the object collides with the ground it will lift off a few dust or sand particles from the ground, so I can understand that the energy of the object was transferred into all those dust particles, but when the dust particles in turn, fall to Earth, where does the initial Energy remains?
The short answer is that most of the energy ends up as heat.
Most of the energy will be turned from kinetic (speed of object) to thermal (heating up of impact area). Immediately after the impact this heat will be quite evident. After some time the heat will dissipate and spread over a larger area until it matches the ambient temperature. However, the heat is still there, just spread out so thin it's not as noticeable.
1. What is initial energy?
Initial energy refers to the total amount of energy present in a system before any changes or transformations occur.
2. Where does initial energy come from?
Initial energy can come from a variety of sources, such as chemical reactions, nuclear reactions, or external forces like gravity or electricity.
3. How does initial energy remain in a system?
Initial energy remains in a system through the principle of conservation of energy, which states that energy cannot be created or destroyed, only transferred or transformed.
4. What factors affect the amount of initial energy in a system?
The amount of initial energy in a system can be affected by the types of energy present, the efficiency of any energy transfers or transformations, and external factors such as temperature or pressure.
5. How can we measure and quantify initial energy?
Initial energy can be measured and quantified using various units such as joules or calories. It can also be calculated by adding up the individual energies present in a system, using equations such as the law of conservation of energy or specific energy formulas depending on the type of energy involved.
  • Other Physics Topics
  • Quantum Physics
17K
