How does the normal force change when performing different movements?
In summary: FN on your foot would definitely be less). And then if you lift your foot off the ground, the FN goes back to what it was before, because the ground is still exerting a force on it. Stomping, on the other hand, seems to involve a different kind of action: you're lifting your foot off the ground, and then pushing it back down. So in that case, it seems like the FN would be greater the longer your foot is off the ground (since the ground is still exerting a force on it).
more_torque
This is my first post on PF. I've decided that I really want to learn physics, not for school, but because physics can be fun!
I'm trying to understand what FN is. I understand it is the force exerted by the ground working upwards contrary to the force of Earth's gravitational pull.
I understand that FN is your weight when standing. I also know that it decreases while you bend down (during the duration of the bend), and stand or jump up (during the time you're pushing off the ground). However, I'm confused about situations that are a little more complicated.
Say you're standing, and drive one of your feet into the ground. It seems to me that all you're doing is shifting your weight from one foot the other. Is that what's really going on? Is it possible to increase your weight by pushing your foot into the ground below you?
What about stomping? In the previous case, we didn't lift the foot up off the floor, just pushed it downwards. What if we lift a foot off the ground and stomp? The ground has to exert a corresponding FN to counter the downward drive of the foot. But I'm not sure if a simple shift in weight is going on between one's two feet, or if one needs to add mg and the ma (where a is the upwards acceleration provided by the floor) to get FN. Simply put, is it possible to stomp greater than one's weight?
All of the above questions ultimately derive from an uncertainty about how forces act, not on a solid object, but on a person with joints and limbs.
The Normal Force is perpendicular to the surface the force is being exerted on.
Could be on a wedge , too, and points away from the surface in the direction of unit normal.
if you jump or stomp your feet you would get more than the regular normal opposing force you might get if you just stood on a wedge or planar surface.
By jumping you push the surface and the surface pushes you in response, You gain Kinetic energy as you jump. And as you land your mv=p ( momentum ) has changed and to nullify that momentum you need a greater force as a response or when you stomp your feet, you are using energy from your upper body to do the stomp. that energy translates into the momentum of your foot.
Think of it this way :
EQN :
p=mV
dp=v dm+m dv
dp = m dV for zero mass change
you can only zero that momentum in the way that you exert a counteracting force for t seconds.
m *Vf -m *Vi=integral ( F dt )
Thanks for the response. I'm still confused about the difference between 1) simply driving your foot into the ground without lifting it up before, and 2) stomping.
The way I see it, 1 and 2 are essentially the same, except that FN for 2 would probably be greater.
In the first instance, you're pushing down into the ground, so there must be a greater FN on that foot for the time period you're foot is going lower (say, on carpet . . . but if you were on a hardwood floor, all the pushing down you could do wouldn't make a difference, since their is no change in velocity, right?).
However, I also feel my weight shifting to that foot away from the stationary foot. How does one know that FN isn't constant, and that all that is occurring is a different division of FN? Instead of FN being apportioned equally to both feet, a more unequal division alone could result. (Or maybe that simply is what's occurring, and after the momentary period where one's foot is being driven down and the normal force is increasing, the normal force returns to one's weight and you're left with it's unequal apportionment among the feet.)
I'm just trying to see exactly when the normal force is increasing, when equal to one's weight, and how that corresponds the actual action of pressing one's foot down.
In the case of stomping, all of one's weight is on one foot, then the second foot is suddenly being brought down. At the time of impact, their is a downward acceleration of the foot, and, thus, two downward vectors (mg and ma), and a corresponding FN, equal to their sum, that lasts for the duration of the deceleration before being replaced by a normal force equal to mg. If the account given for 1 above is right, then one should be left with with an FN equal to one's weight, but simply divided unequally between one's two feet.
Well, when thinking try to keep these in mind
1) integral(F * dr ) = Change in Kinetic Energy ( here the dot product )
2)integral(F*dt)=Change in m*v ( here simply product )
These 2 eqns give us an intuition of how the Force changes.
All help I can do is this much, sorry :(
There is also the matter of elastic/inelastic collisions in one of your explanations ( ie : carpet, hardwood )
To be concise,
when 2 things collide, they deform each other which turns to heat energy ousted.
If they do not harm each other at all that is Perfectly Elastic
For the elastic and inelastic parts, momentum is conserved but only in the elastic part that is Kinetic Energy is conserved.
Keep in mind that in the case of stomping you are adding biochemical as well as potential energy into the system and then convert them to kinetic energy. This means that you do not only let your foot fall under the acceleration of gravity, you also expend biochemical energy to accelerate it with your muscles.
This manifests itself in the form of larger momentum since, the result of adding energy to your foot is increasing the speed with which it will collide with the ground.
So, to keep it simple, just keep in mind that there is not only mass at play here, but the explosive motion of the body as well :wink:
Thanks meldraft!
I understand that you're adding biochemical energy to the system, and that that's the reason for the increased velocity and KE of you're stomping foot at the time of impact. I think that's also why I was confused about this problem in the first place - not only are you a body with mass, but you're a massive body whose appendages can themselves exert forces independent of the Earth's gravitational force.
I think that what's happening is that the normal force increases as my foot hits the ground and is decelerated from whatever vi it has to 0=vf over a small time interval. This is from the equation dF*dt=m*dv. It is only during this time interval that your FN is greater than your weight. Once your foot is stationary, FN
returns to your weight, and all you're left with is an unequal apportionment of FN
between your feet (since your weight has shifted due to the stomp).
Could you tell me if the above account is accurate?
In order to calculate it, what I'm thinking right now is that total force FN=m1g + m2a, where m1 is your body's mass (including the mass of the stomping foot) m2 is your foot's mass, and a is the acceleration of your foot as it hits the floor. The FN calculated would be the maximum FN the ground exerts on you (at initial impact). Is this true?
1. What is force normal?
Force normal is the force that acts perpendicular to the surface of an object. It is also known as the support force or the contact force.
2. How is force normal different from other types of forces?
Force normal is different from other types of forces because it is always perpendicular to the surface of an object and is caused by the contact between two surfaces. Other types of forces, such as gravity and friction, can act in different directions and have different causes.
3. How is force normal calculated?
Force normal can be calculated using the formula FN = mgcosθ, where FN is the force normal, m is the mass of the object, g is the acceleration due to gravity, and θ is the angle between the surface and the vertical direction.
4. What is the purpose of understanding force normal?
Understanding force normal is important in many scientific fields, such as physics and engineering. It helps us determine the stability and equilibrium of objects, and is essential in designing structures and machines.
5. How does force normal affect the motion of an object?
Force normal can affect the motion of an object by either supporting or opposing the force of gravity. If the force normal is greater than the force of gravity, the object will be pushed upward, and if the force normal is less than the force of gravity, the object will be pushed downward. Force normal can also affect the direction and speed of an object's motion if it is not acting perpendicular to the surface.
  • Classical Physics
11K
  • Classical Physics
