How Do You Calculate Work on a pV Diagram When Pressure Varies?
  • Thread starter doggieslover
  • Tags
    Diagrams
In summary, work done by the gas during process 1→3→6 can be calculated by finding the area under the curve of the pV graph between the initial and final volumes, which is represented by the integral of p.dV. This accounts for non-constant pressure by taking into account the change in pressure as a function of volume.
doggieslover
34
W = p*deltaV only holds for the case of constant p, that is true.
What is the general form of the work eqn. that holds for all types of paths? (Hint: It also invloves p and V, and it must reduce to the W = p*deltaV, when p is constant)
Is it W = p1V1 - p2V2?
No, recall that work done is given by W = F.x, hence dW = F.dx, where dx is a infinitesimal displacement in the direction of the force.
For ideal gases, F = pA, hence dW = pA.dx, or dW = p.dV.
Work is then found from integrating p.dV, with respect to V from Vfinal to Vinitial, which can be interpreted as the area under the pV graph
So pV from Vi to Vf, but isn't p still constant in this case?
The graph indicates that p is NOT constant.
no, p as indicated in this equation of the general case, is a function of V.
okay let's say from 1 to 3, pressure is decreasing from 3p to 2p, how would I apply that to pV| from Vi to Vf?
p(3V) - p(2V)?
Integration between two points of a function can be simplified by taking the area under the curve. Because, the graph is linear, it is very easy to find the value of the integral from 1 - 3 - 6, because the area under the curve is a trapezium (or trapezoid).
What is a pV diagram?
A pV diagram, also known as a pressure-volume diagram, is a graphical representation of the relationship between pressure and volume of a gas at a constant temperature. It is used to visualize the changes in pressure and volume of a gas during a thermodynamic process.
How is a pV diagram useful in understanding thermodynamics?
A pV diagram helps in understanding the behavior of gases during various thermodynamic processes, such as isothermal, adiabatic, and isobaric processes. It also helps in calculating important parameters like work, heat, and efficiency in these processes.
What do the different regions in a pV diagram represent?
The different regions in a pV diagram represent different thermodynamic processes. The horizontal lines represent isothermal processes, the vertical lines represent isobaric processes, and the sloping lines represent adiabatic processes.
How can one determine the work done on a gas using a pV diagram?
The work done on a gas can be determined by calculating the area under the curve on a pV diagram. This area represents the amount of energy transferred to or from the gas during a process.
What are some real-world applications of pV diagrams?
pV diagrams have various real-world applications, such as in refrigeration systems, internal combustion engines, and gas turbines. They are also used in industrial processes to optimize the efficiency of gas compression and expansion. Additionally, pV diagrams are essential in the study of thermodynamics and its applications in fields like engineering and physics.
11K
