Understanding Red Shift: A Derivation from Classical and Relativistic Physics
In summary, the conversation discusses the concept of redshift and its explanation in both classical and relativistic physics. The derivation of redshift based on classical and relativistic physics is presented, along with the relationship between energy and momentum for photons. The conversation also mentions the potential for redshift to be calculated using general relativity in cases such as black holes and Big Bang cosmology. Finally, the idea that redshift is a result of differences in perception rather than changes in the photon itself is also mentioned.
FireStorm000
169
This is another one of those concepts where I understand what happens at the macroscopic level, but don't understand the why, or rather what is happening at the fundamental level. Now my understanding of QM has improved a fair amount in the last week thanks to some help from ZapperZ, but I'm still having trouble moving from a relativistic understanding of the photon to a QM one. Below is a derivation of redshift based on some classical and relativistic physics:
  1. First, "the energy carried by a photon is related to it's frequency"http://en.wikipedia.org/wiki/Photon#Physical_properties"
  2. Second, energy is conserved. What this means, at least to my understand is that the photon must loose energy as it moves out of the potential well created by a massive object.
  3. From a classical perspective, gravity acts on an object's total mass? (Not sure about this one). Total mass includes relativistic mass, so if true, gravity acts on photons.
  4. We can derive mass of a photon from the following:
    • Photons are have m0 of zero and speed c
    • Relativistically, momentum p = m0[itex]\gamma[/itex]c and energy E = mTc2
    • m0[itex]\gamma[/itex] is total mass mT, which is mrel + m0. That gives us the substitution mT = mrel for the photon due to the identity property of addition.
    • a little algebra on the definitions of relativistic p and E gives E / c = p
    • the above means that, for photons, energy is proportional to momentum, rather than the classical relation.
    • E / c = mrel c, or E / c2 = mT = mrel
  5. And gravity well can be approximated as F = G mT M / r2
  6. realizing that force is the change in momentum F = dp/dt; Recall that v = dr/dt, dt/dr c = 1. dp/dt = d/dt(mc) = dm/dt c.
  7. and recall mT = E c-2
  8. We're interested in red shift, and thus frequency. E = h [itex]\omega[/itex] / (2[itex]\pi[/itex]), m = h/(2[itex]\pi[/itex]c2) [itex]\omega[/itex], dm/dt = h/(2[itex]\pi[/itex]c2) d[itex]\omega[/itex]/dt
  9. combining: F = G mT M / r2 ->
    ([STRIKE]c[/STRIKE])( [STRIKE]h/(2[itex]\pi[/itex][/STRIKE][STRIKE]c2[/STRIKE]) d[itex]\omega[/itex]/[STRIKE]dt[/STRIKE] ) ([STRIKE]dt[/STRIKE]/dr [STRIKE]c[/STRIKE]) = (G M / r2) ([STRIKE]h/(2[itex]\pi[/itex][/STRIKE]c2) [itex]\omega[/itex]) ->
    d[itex]\omega[/itex]/dr - [itex]\omega[/itex] GMr-2c-2 = 0
  10. Solving the differential: [itex]\omega[/itex] = [itex]\omega[/itex]0eGM/c2(1/r-1/r0)
As per that equation, a photon leaving the surface of the sun and traveling to 1au is red-shifted to .9999978905 of its original frequency, or a change of -2.1095E-4% of the original. One could also see that a photon emitted from a singularity is red-shifted to a frequency of zero. On the extreme, a photon from the accretion disk of a black hole of 1000 solar masses from 1 Earth radius moving to infinity red-shifts to .791386 or about a 21% decrease of its original wavelength. A photon falling into Earth's well blue-shifts 7.058E-8% of the initial frequency, an (I should think) barley detectable amount.
So, are my results correct, and how would one do the equivalent from the quantum perspective, using the wave-function model for light?
Um, I forgot the question.
But the first five or siz equations seem fine...did not look further...
I've never seen a quantum physics explanation for redshift...a quick search did not turn up anything interesting:
A special relativistic redshift formula (and its classical approximation) can be used to calculate the redshift of a nearby object when spacetime is flat. However, many cases such as black holes and Big Bang cosmology require that redshifts be calculated using general relativity. Special relativistic, gravitational, and cosmological redshifts can be understood under the umbrella of frame transformation laws. There exist other physical processes that can lead to a shift in the frequency of electromagnetic radiation, including scattering and optical effects; however, the resulting changes are distinguishable from true redshift and not generally referred as such (see section on physical optics and radiative transfer).
http://en.wikipedia.org/wiki/Red_shift
The way I would put it is, nothing is happening to the photon at all, so there's no "micro physics" to understand there in the first place. Instead, something is happening to the observer, or there is some difference in the environment of the observer relative to an observer where the photon was emitted, and that difference is causing them to interpret observations of the photon differently. That pretty much holds for all relativistic effects. Remember also that "causes" in physics are rarely unique, they often depend on the point of view taken in answering the question. (For example, what is the microphysics that causes two charges to attract? Or is the observation that they attract the cause of our having dreamt up the microphysics?)
1. What is red shift?
Red shift is a phenomenon observed in astronomy where the light from an object appears to have shifted towards the red end of the electromagnetic spectrum. This is caused by the expansion of the universe, which stretches the wavelengths of light as it travels through space.
2. How is red shift related to the expansion of the universe?
Red shift is directly linked to the expansion of the universe. As the universe expands, the space between objects also expands, causing the wavelengths of light to stretch and appear more red. The amount of red shift observed can be used to calculate the distance and speed of the object.
3. What is the difference between classical and relativistic red shift?
Classical red shift is based on the principles of classical physics, where the wavelength of light is stretched due to the relative motion of the source and observer. Relativistic red shift takes into account the effects of gravity and the curvature of space-time, resulting in a more accurate calculation of red shift for objects with high velocities or in strong gravitational fields.
4. Can red shift be observed in objects other than galaxies?
Yes, red shift can be observed in a variety of objects such as stars, quasars, and even the cosmic microwave background radiation. It is a universal phenomenon that occurs with any object that emits light and is affected by the expansion of the universe.
5. How does red shift support the Big Bang theory?
Red shift is one of the key pieces of evidence supporting the Big Bang theory. The observation of red shift in distant galaxies indicates that the universe is expanding, which is a fundamental component of the Big Bang model. Additionally, the amount of red shift observed in objects at different distances can be used to calculate the age and size of the universe, providing further support for the theory.
  • Quantum Physics
  • Quantum Physics
  • Atomic and Condensed Matter
