Understanding the basic concept of a Limit
In summary, the conversation is about understanding the concept of a limit in calculus. The participants discuss different aspects of a limit, including its definition, its relation to the independent and dependent variables, and its application in different scenarios. They also mention the importance of avoiding complicated math jargon when explaining the concept to a beginner. Ultimately, the conversation provides a clear understanding of a limit and its significance in calculus.
nycmathguy
TL;DR Summary
Basic concept of a limit.
Hello everyone. How are you? I want to learn calculus so badly. I plan to do a self-study of calculus l, ll, and lll. Before thinking so far ahead, I need a clear, basic definition of the concept of a limit. Textbook language is never easy to grasp unless the student is gifted. I am not gifted mathematically but love the subject.
I understand the limit idea to be the following:
•The value a function is tending to without actually getting there.
•The height a function is trying to reach in terms of the y-axis.
•In terms of a point (x, y), the limit is (value the function is tending to, limit). In other words, x = the value a function is tending to and y = the limit, the height of the function.
Is my understanding of a limit clear or not?
Likes Delta2
You are sounding a bit confused. E.g. "without getting there" is wrong: ##\lim_{x \to 2} x^2=4## so the function ##f(x) =x^2## is actually getting to the limit ##4.## Things are getting a bit more complicated if infinities, or holes come into play.
##L:=\lim _{x\to a} f(x)## describes the value of ##f(x)## if ##x## approaches ##a## on some path. It does not say whether ##f(a)## is defined or not. All cases can occur: ##L=\infty \, , \,L=-\infty \, , \,L=f(a) \in \mathbb{R}## or ##f(a)## is undefined, although the limit ##L## exists (a gap in the graph of ##f## at position ##x=a##).
Likes Kashmir
I think you might confusing two different things:
  1. The value that the independent variable ##x## is tending to, which we may refer to as ##x_0##
  2. The value that the dependent variable ##y=f(x)## is tending to (this is the value the function is tending to and it is equal to the limit L)
So when we write $$\lim_{x\to 2}x^2=4$$ we mean that , AS the value of the independent variable ##x## is tending to 2 (##x_0=2## in this case), the value of the dependent variable ##y=x^2## is tending to the limit L=4.
Likes Kashmir and nycmathguy
As x tends a number, y = f(x) is approaching the limit L.
Yes this is absolutely correct.
Likes nycmathguy
You want to be careful about limiting your thinking (no pun intended) to a particular axis orientation. A limit can be on either axis depending on how a function is defined and for that matter limits are not confined to 2D.
This idea is totally new to me. I am going through the textbook on my own. No specific reason other than learning the material. Let's stick to the basics of calculus by avoiding math jargon and complicated symbols that mean nothing to a novice calculus self-study individual.
Here is a better definition:
You say?
You say?
He might me limiting his thinking, but you expanding it too much, by start talking about multivariable calculus when the OP said he just starting learning calculus I.
PeroK said:
I say that doesn't even make sense
this is some sort of overstatement by you. I read the first link and I find that what the OP says at #8 is very similar to what the link says. Why do you say it doesn't even make sense?
Because it should be:
If as ##x## tends to ##a##, ##f(x)## tends to ##L##, then we say that ##L## is the limit of the function ##f(x)## as ##x## tends to ##a##; and, we write: $$\lim_{x \rightarrow a}f(x) = L$$ Trying to improve on this is a mathematical dead-end, IMO.
Likes MidgetDwarf
There's nothing in the definition of a limit that says that it doesn't "actually get there".
First, if we have a constant function ##f(x) = c##, then we have (for any ##a##) $$\lim_{x \rightarrow a} f(x) = c$$ and we see that the limit is attained.
Also, we have: $$\lim_{x \rightarrow 0} x \sin \frac 1 x = 0$$ and the function ##f(x) = x \sin \frac 1 x## attains the limit value ##0## an infinite numbers of times for ##x \ne 0##.
I must be brain dead cause I also find what you saying here very similar to what the OP says at #8, you just expand it a bit further.
Have a cup of coffee and read them both again!
  • Haha
Likes Delta2
I thank you for your reply. However, I am looking at calculus for the first time outside of a classroom setting. I am slowly going through the textbook one chapter, one section at a time. The limit of trig functions is still a few chapters and sections ahead.
Likes Delta2
Draw some graphs of possible functions and look at what happens to the graph if ##x## approaches certain points. E.g.
Likes nycmathguy
For more details on limits checkout the 3blue1brown youtbe sequence called the Essence of Calculus. Its ten short 10min videos covering this and other key concepts.
Likes The Fez and fresh_42
We will get to graphs as I journey through the textbook. I'm excited about calculus events my PSA level is 4.9. Pray for me.
Likes fresh_42 and Delta2
nycmathguy said:
my PSA level is 4.9
That's a bit high for your age. Are you under a doctor's care for it?
Yes, my primary care doctor at the VA Hospital wants me back in 6 weeks for another PSA. There are men with higher PSA levels that do not have cancer. I am not going to quickly run into a prostate biopsy situation. Let's see what happens in 6 weeks. I'll keep you posted. Thank you so much for asking.
Likes Delta2, berkeman and fresh_42
This video, and channel overall, should help you on your journey (patrickJMT has some of the BEST videos on computational calculus IMO):
Likes nycmathguy and Delta2
Thanks for the video clip. I will check it out.
I think I understand where you are coming from with the "without getting there" language because I used to actualky use that in teaching limits, although I sympathize with opponents of it.
Take an example of a limit if a sequence, (which is a function defined on the positive integers), like f(n) = 1/n. We ask for "the limit of f(n) as n goes to infinity". To me, the entries in the sequence are approximating values, and the limit is the number they are trying to approximate. So ask yourself what number do the numbers 1/n get closer to as n gets larger and larger. The answer is zero. That is, if you go out far enough in the sequence, the elements get, and remain, as close to zero as you might wish. I.e. if you want them to be closer than .0001, then after n gets larger than 10,000, every later sequence entry 1/n will be closer to zero than .0001. So zero is the limit of the sequence. In this case no element of the sequence ever equals zero, so although no entry in the sequence actually gets to zero, every element, far enough out, gets as close as desired.
Now here is another sequence: f(1) =1, f(2) = 2, f(3) = 3, f(4) = 4, f(5)= 1/5, f(6) = 1/6, f(7) =0, f(8) = 0, f(9) = 0, ...f(n) = 0 for every n ≥ 9. This sequence fools around for a while getting larger, but soon turns around and starts getting smaller, and all of a sudden jumps to zero, where it remains forever after. Since the only thing that matters in a sequence is where it eventually goes, this sequence is also (eventually) approximating to, i.e. heding ultimtely toward, zero. Indeed if you wnt to get an approximation to within .000001, of zero, you can take any sequence entry further out than f(7). So here again the limit is zero. But in this case, most elements of the sequence do actually get to zero, the limit.
So sometimes the sequence actualy gets to the limit "early", and sometimes it does not. This doies not matter at all for the notion of a limit. The limit is the number that the sequence ultimately zeroes in on, whether it actually gets there earlier or not does not matter.
I have to go now, but the case of functions is similar. I.e. when looking at the limit of a function like f(x) = (x^2-4)/(x-2), as x goes to 2, we are interested in what number is being approximated by these values f(x) when x is very near 2, but not equal to 2. That is because the function is not defined at 2. This is analogous to the fact the sequence function above was not defined at n = infinity.
It is more confusing to consider functions like f(x) = x^2, and ask for the ,imit as goes to 2, because this function is defined at 2, i.e. f(2) = 4. Since the limit of this function as x goes to 2, is also 4, you might say that the function does get to its limit, namely the limit as x goes to 2, is whatever number x^2 is fgettoing closer to as x gets closer to 2, and this is 4. But you are supposed to compute the limit only by looking at numbers x with x ≠ 2, so really, in my opinion this function also does not "get to 4", at least not as long as x has not got to 2.
The link is that some functions are defined at the point that x is going to, i.e. this f(x) = x^2 is defined at x=2, and one can ask two separate questions: 1) is there a limit (and what is it), of x^2, as x goes to 2 without reaching it? 2) does that limit, equal the value of f(2)? If so, the function is a good function, called continuous.
got to go.
Likes nycmathguy
got to go.
Interesting. Thank you.
nycmathguy said:
Summary:: I need a clear, basic definition of the concept of a limit. Textbook language is never easy to grasp unless the student is gifted.
We have to distinguish between a clear intuitive concept of a limit versus the formal definition of a limit, which is perhaps what you encounter in your textbook. The formal definition is the only definition that is reliable for purpose of proving things about limits. The intuitive definition is what most students learn first.
Furthermore, the phrase "definition of limit" is ambiguous. There are different types of limits. The outstanding feature of the intutiive definitions of limits is the concept of a process taking place in time or in steps. In the formal definition of limit there is no mention or need of such a process. For example, the formal definition (or its notation) may contain language such as "as x approaches", however there is nothing in the formal definition that defines a process called "approaching". If you need to work problems in a textbook that require you to understand the formal definition (the so-called "epsilon-delta definition") of a limit, then you have to progress beyond the intuitive definition, but the intuitive definition is where you should start.
Since the op has left the site, it’s a good time to close this thread.
Thank you all for contributing here.
What is a limit?
A limit is a fundamental concept in calculus that describes the behavior of a function as its input approaches a certain value. It represents the value that a function is approaching, but may never reach, as its input gets closer and closer to a specific value.
Why is understanding limits important?
Understanding limits is crucial in calculus because it allows us to analyze the behavior of functions and make predictions about their values. It also serves as the foundation for more advanced concepts such as derivatives and integrals.
How do you find the limit of a function?
The limit of a function can be found by evaluating the function at values approaching the desired input value. This can be done algebraically, graphically, or numerically using a table of values.
What is the difference between a one-sided limit and a two-sided limit?
A one-sided limit only considers the behavior of a function as its input approaches the desired value from one side, either the left or the right. A two-sided limit takes into account the behavior of the function from both sides of the desired value.
Can a function have a limit at a point where it is not defined?
Yes, a function can have a limit at a point where it is not defined. This is because a limit only considers the behavior of the function as its input approaches a certain value, not necessarily the value of the function at that point.
  • Calculus
  • Calculus
  • Science and Math Textbooks
