How can I understand the motion of a particle on a cycloid trajectory?
  • Thread starter fayled
In summary, the equations x=0, y=E(wt-sinwt)/wB, z=E(1-coswt)/wB and (y-Rwt)^2+(z-R)^2=R^2 describe the trajectory of a particle with charge Q and mass m at rest at the origin at t=0, with an electric field E=Ek and a magnetic field B=Bi. The solution can also be recast into the form (y-Rwt)^2+(z-R)^2=R^2, which represents a circle with radius R moving along the y-axis with speed Rw. This motion can be visualized as a point on the rim of a rolling wheel, with the equations y=Rcos(ωt
fayled
177
Suppose we have a particle of charge Q, mass m at rest at the origin at t=0, with an electric field E=Ek and a magnetic field B=Bi with i,j and k the cartesian unit vectors. Then the solution for the trajectory of this particle is
x=0,
y=E(wt-sinwt)/wB,
z=E(1-coswt)/wB,
where w=QB/m.
These parametric desribe the motion of the particle, but they can be recast into the form
(y-Rwt)2+(z-R)2=R2
where R=E/wB which also describes the particle motion. This form is that of a circle, radius R, with centre (0,Rwt,R) that travels in along the y-axis with speed Rw.
Now my book states
'The particle moves as though it were a spot on the rim of a wheel, rolling down the y-axis at speed Rw. The curve generated in this way is called a cycloid.
However I've always had trouble being able to properly see this from the equations, but haven't worried about it too much. However I think not understanding it is stopping me from solving a similar problem with a slightly more complicated motion.
So my problem is this. The equation (y-Rwt)2+(z-R)2=R2 describes the particle trajectory. All I can see from this is that at time t, the particle must be on a circle of radius R, centre (0,Rwt,R), which tells me the circle is moving along the y-axis. How can I see that the particle moves around this circle (and so appears to be a point on a rolling wheel)? And in order to appear like a rolling wheel, the particle would need a certain speed around the circumference of the moving circle (I believe it would have to move around the circumference at speed Rw, whilst the circle itself moves with this speed along the y-axis) - how do I see this is satisfied? Thanks.
Does this help?
You can not, in the same way as, when you state that ##x^2+y^2=R^2##, that doesn't reveal anything about the position as a function of time. All you get is the locus of the positions: all positions are on the circle around the origin with radius R.
Whereas ##x=R\cos\omega t,\ y = R\sin\omega t## expresses x and y as functions of time t.
In other words, the solution you begin with expresses y and z as functions of time t. The recasting only gives a relationship between y and z.
MrAnchovy said:
Does this help?
Nope, it just states (or show in the case of the animations) what the parametric equations/cartesian equation describe/describes - in short, I would like an explanation of why they describe what they do.
I see. Is there a way of getting the motion from the parametric equations then?
Well, as we have seen, the relationship between y and z can't help you there. So we have to stick to the functions of time. You can kind of 'build it up', for example:$$y=R\cos\omega t$$
$$z = R\sin\omega t$$describes a point moving counterclockwise around a circle around the origin with radius R. Agree? Next:$$y=R\cos\omega t$$
$$z = -R\sin\omega t$$describes a point moving clockwise around the same circle. Then:$$y=R\cos\omega t$$
$$z = R(1-\sin\omega t)$$lifts the circle so that it 'rolls on the y-axis'. And finally:$$y=\omega Rt + R\cos\omega t$$
$$z = R(1-\sin\omega t)$$lets the circle roll in the positive y direction at the proper rate.
If you want the functions in your post #1 that start at (0,0,0) at t=0, shift by ##\pi/2##:
##\cos \left(\phi + \pi/2\right ) = - \sin\phi## and
##\sin \left(\phi + \pi/2\right ) = \cos\phi##
Great, this was exactly what I was looking for. The very last part is confusing me though - although adding pi/2 clearly gives the correct answer, looking at the scenario I would want to be subtracting pi/2 phase. If z is upwards, y is to the right, surely out θ=wt is measured from the y-axis anticlockwise to be consistent with your first step of the anticlockwise circle. So then if I want things to start at (0,0,0), I need to shift everything back by pi/2, i.e subtract it.
My thingy starts at R,R for t = 0. So I have to let it roll a quarter turn, ##\pi/2##, to let z=0 and then y is ##\pi R/2##. The transform needed is ##\omega t'= \omega t - \pi/2## and I realize that I also need to shift y: ##y'= y - \pi R/2##.
A bit confusing, I admit.
1. What is a cycloid?
A cycloid is a curve that is traced by a point on the circumference of a circle as it rolls along a straight line. It is a specific type of trochoid curve, which is a curve traced by a point on a circle as it rolls along a fixed circle.
2. What is the significance of the cycloid?
The cycloid has many applications in mathematics, physics, and engineering. It is used to model the motion of pendulums, the shape of gears, and the trajectory of projectiles. It also has aesthetic value and has been studied by mathematicians for centuries.
3. How is a cycloid mathematically described?
Mathematically, a cycloid can be described using parametric equations, where the x and y coordinates of a point on the curve are given in terms of a parameter t. The equations for a cycloid are x = a(t - sin(t)) and y = a(1 - cos(t)), where a is the radius of the rolling circle.
4. What is the relationship between the cycloid and the brachistochrone problem?
The brachistochrone problem is to find the shape of a curve that a ball must follow to reach a given point in the shortest amount of time under the influence of gravity. The solution to this problem is a cycloid, making it a fundamental curve in the study of mechanics and calculus of variations.
5. Can a cycloid be generalized to higher dimensions?
Yes, a cycloid can be generalized to higher dimensions. In three dimensions, it is called a trochoid and is traced by a point on a sphere as it rolls along a fixed sphere. In four dimensions, it is called a cycloidean and is traced by a point on a hypersphere as it rolls along a fixed hypersphere.
  • Electromagnetism
