Understanding Wanning Crescent.
  • Thread starter nukeman
In summary, a thin sliver of a waning crescent moon will be visible in the early morning, in the east due to its location in the sky and its relationship with the sun. It will be visible near the horizon as it rises before the sun, but not when the sun is in the sky due to glare.
nukeman
655
Am I correct here.
Wanning crecent would a thin sliver of a Moon visible in the early morning, just before sunrise. Since the moon rises in the east, and since this moon phase is best seen before sunrise, it will be located in the east.
Also, would wanning crecent be visable near the horizon, or high in the sky?
Thanks!
Astronomy news on Phys.org
You have the right idea. Now you ask will it be high or low in the sky. Think about the relationship between the sun and the moon.
What is the apparent distance between the moon and the sun at this time?
Answering this tells you where in the sky the moon is.
This distance would be close correct? So, that would make the sun high in the sky?
Since the moon is "close" to the sun, it will be near by no matter where the sun is. In the early morning you wll see it rise before the sun, then when the sun is in the sky, the moon will not be visible due to glare but it is still there.
I see...So then wanning crecent would be visable near the horizon, just because as it rises, you cannot see it because of the sun.
1. What is "Waning Crescent"?
"Waning Crescent" is one of the eight phases of the lunar cycle. It occurs when the illuminated area of the moon visible from Earth decreases in size, creating a thin crescent shape. This phase marks the end of the lunar cycle and the beginning of a new cycle.
2. How long does the Waning Crescent phase last?
The Waning Crescent phase typically lasts for about three days. However, the exact duration can vary depending on the specific position of the moon in its orbit and the observer's location on Earth.
3. What causes the Waning Crescent phase?
The Waning Crescent phase is caused by the relative positions of the Earth, moon, and sun. As the moon orbits around the Earth, the amount of sunlight reflected off its surface changes, resulting in different phases. During the Waning Crescent phase, the moon is positioned between the Earth and the sun, with its illuminated side facing away from Earth.
4. What can we learn from observing the Waning Crescent phase?
By observing the Waning Crescent phase, we can learn about the cyclical nature of the moon's phases and its relationship with the Earth and sun. We can also use this phase to track the passage of time and plan activities such as farming or fishing based on the lunar calendar.
5. Are there any cultural or spiritual beliefs associated with the Waning Crescent phase?
Yes, many cultures and spiritual beliefs have associated the Waning Crescent phase with endings, release, and letting go. It is often seen as a time for reflection and introspection, as well as a symbol of transformation and the cycle of life and death.
  • Astronomy and Astrophysics
  • Earth Sciences
