Uniform circular motion with a pendulum
In summary: I could check with my lecturer, but I don't think it matters too much.This says I need 2948xp to ding! You have any ideas how many tough physics bosses problems I'll have to solve to get there?!? :(
  • #36
Looking nice! :)
(Again, where's the coffee stain?)
It's my electronics exercise notebook that got the biggest hit. :)
http://img707.imageshack.us/img707/7227/coffeey.jpg
That is, you've drawn N smaller than W.
That doesn't leave much for any net centripetal force does it?
Perhaps the hammerhead will be flying away...
Hope it doesn't impact something else!
Waaaaaaaait a second now, the length of the vector was completely arbitrary. If I knew it mattered, I'd wait for the results before drawing them. But other than the lengths, it's correct right?
And you're right, the speed turns into a force.
Right there you have an entirely new beast called "impulse", which is force times time.
I don't think your studying material covered that yet! :)
Note that we have no information about how great this force would be, although we can say a little on how large the change in "momentum" will be (another, or rather the same, new beast) .
That's a fascinating input!
I love how you expand the engineering realm to me when I study something basic, and you show more something more advanced that I'm able to understand :)
Eep! It does?
Nah, was just looking for a joke ;)
  • #37
Earlier I wrote this:
I used the diameter for "h" -- is that right? it's the change in position, delta x. So, the change in position is 1.6m!
Oh, and am I right in saying that the change in position is 1.6 and not pi? because we're looking at the displacement, if I understand correctly.
  • #38
There! That's proper engineering! Showing the results of your actions! ;)
Didn't you think that, before you made your calculations, it mattered whether the hammer would be flying away or not? :devil:
All in a fraction of a second that apparently you're waiting for! :)
EDIT: And yes, it is correct, regardless of the lengths.
Any time! :)
Good!
Because a point mass is a pointy thingy with very little size.
Or rather no size at all! :wink:
Yep! :smile:
As tiny-tim already stated, it does not matter by which route you got from A to B, only the distance (in height!) matters in conservation of energy.
  • #39
Yes, you're right, I should've intuitively realized that. BUT, do we draw vectors longer based on their magnitude, or is it just being pedantic?
But it's not really a point mass because its mass is defined, right? So it's a 200[N] point mass, if anything :)
Brilliant :)
  • #40
Yes, we draw vectors longer based on their magnitude.
That brings us to "vector addition".
There are 2 ways to add vectors: geometric and algebraic.
Geometric means that you draw all vectors carefully on scale, and when you draw each vector head-to-tail after each other, you can measure the length of the resulting vector on paper.
Algebraic means that you typically calculate the x component and the y component of each force and that you add those numerically.
I think you're already quite used to that in your mechanics problems.
There's no need to do things geometrically in your case, although it would be nice if what you draw is more or less geometrically correct. :)
Hmm, 200 N is not a mass - it's a force, or rather, a weight.
And for a point mass, its mass is always defined. It's just that its size is not defined! :smile:
  • #41
We never had to measure vectors before, or draw them carefully to scale! Sounds like a system I rather not learn for now, but interesting nevertheless :)
Yep!
Duly noted :)
Fair enough!
  • #42
Couple of questions.
1) This does not appear to be uniform circular motion anywhere, but rather NON-uniform circular motion. Is that right?
2) I'm a bit confused as to why I go about ADDING 200 [Newtons] IF the normal force is up, and W is down.
3) My F turned out being 799.18 [N]. I presume F is N, right?
Not sure why I should really add 200 to F and not decrease. Does F means "all the vertical forces" or just N?
Posted my latest full calculation of F.
http://img19.imageshack.us/img19/7048/newcalculations.jpg
  • #43
Right! :)
No.
F is your net resultant force that must be equal to the centripetal force.
W and N are the actual forces acting on the hammerhead.
They point in opposite directions and their sum must equal the centripetal force.
So: F = N - W = centripetal force
Which means: N = F + W
So yes, F means all the forces (vertical or otherwise) and not just N.
  • #44
I wish I've been told that before! :) Thanks.
No.
So "F" IS in fact the centripetal force, not "EQUAL" to the centripetal force, yes?
Duly noted :) Excellent. I now feel I can solve other non-uniform circular motion problems.
  • #45
Isn't that the same thing? :confused:
You know, I believe so too! :smile:
  • #46
Heh, I guess. I'm being pedantic :)
Thank you very much!
Btw, where does this formula comes from?
Is it simply sum of all forces = ma? I fail to see how that formula (sum of all forces = ma) relates force, to weight, to normal force; since it really relates mass to acceleration.
  • #47
Yes. That is always the case.
This is called Newton's second law.
First things first, you call it "normal" force - it isn't - it's tensile force (T would have been a better symbol).
Normal force is the force exerted by a surface.
And these are actually 2 formulas.
You have F = sum of all forces = N - W
And you have F = sum of all forces = m a
In statics you usually want the acceleration a to be zero, otherwise your sexy problem might bolt away from you! :smile:
  • #48
Hmm... 2 formulas, that is in fact the same formula?
How does it make sense? And they're meant for different variables? This is a bit confusing, don't you think?
  • #49
Hmm, the first formula is just "vector addition".
The second formula defines the relationship between resultant force and acceleration.
Since they are both equal to the resultant force, they are equal to each other.
  • #50
Hi Femme_physics! :smile:
(just got up :zzz: …)
On a free body diagram I draw them all the same length (if there's room) …
often, you don't know what length they should be anyway.
(of course in a vector triangle the lengths do matter!)
btw, I agree with I like Serena … there's no normal force here, you should use T for tension :wink:
I wish people wouldn't say "centripetal force". :redface:
In this case, T is a centripetal force and since there's only one, it's the centripetal force … T - W is the net centripetal force.
The correct equation to use is (as almost always) good ol' Newton's second law …
net force = mass time acceleration …​
which in this case is
vertical component of net force = mass time centripetal acceleration :smile:
(finally, my small-print earlier was because I assumed you hadn't done centrifugal force :wink:)
  • #51
__________________
Hmm..fair enough. Not sure I 100% get it, but I appreciate the effort :)
Can you please tell me if my notation is correct:
http://img225.imageshack.us/img225/1707/thesteps1.jpg
http://img580.imageshack.us/img580/4421/thesteps2.jpg
Hi Femme_physics!
And W and Fc are in absolute value anyway (I think), since it's the net force
(just got up
Hi tiny-tim!
Good morning ;)
By net force do you mean the absolute value of all the forces acting on the axis?
Hmm. Why's that? Is there something improper in saying that?
  • #52
I mean the sum of all those forces (the resultant force, or total force).
It is confusing you because calling it a force means that you think of it as a separate force, and you want to put it on the LHS of Newton's second law with the other forces … that's double-accounting!
Instead, use mass time centripetal acceleration , and put it on the RHS where it belongs …
that way you won't have problems with the sign. :smile:
Centripetal force is not a separate force.
It is only an alternative name for the radially inward component of tension or friction or other force or forces on a body.
See the PF Library on centripetal force for a full discussion. :wink:
  • #53
Let's see.
I see a few inconsistencies...
You're showing that you use the formula g h = v2 / 2.
(You may want to add a comment that this is about conservation of energy. Not everyone has the super math/physics vision feat! :wink:)
But then you write "Δx".
That's not right for 2 reasons.
It implies it's a horizontal distance (by the use of x), but it's a vertical one.
And you just wrote a formula with "h" in it, so you should use "h" instead of "Δx".
Furthermore you write m = 200 [N].
But m is supposed to be a mass and not a force.
So this should be: m = (200 / 9.81) kg.
Then a little further down you refer to the same mass with a capital "M".
You should use the same symbol, that is, "m".
(When you're referring to the weight you'll use W = 200 N.)
In your formula for Fc you have substituted v, but you seem to have forgotten to square it.
Sorry for being such a nitpicker! :wink:
  • #54
Or delta y?
Well, that's just a given value, I alter it in my equations to kg or Newtons as needs be :) makes sense no?
Noted and checked.
I like your nitpicking, keep it up :)
True, indiscretion, but I did write the squared result for that.
I love nitpickers! :)
  • #55
And while I'm at it: is mass times acceleration always a positive value? How did I know not to write it in a minus in this case?
  • #56
Femme_physics said:
All right! Since you apparently like it, I'll continue with your next picture.
You write here the formula that the sum of the forces is equal to mass times acceleration.
(Newton's good ol second law. :wink:)
But then you write the forces in the wrong order.
Going along with tiny-tim, it should be:
[tex]\sum F = m a[/tex]
[tex]T - W = m \cdot a_{centripetal}[/tex]
with
[tex]a_{centripetal} = \frac {v^2} R[/tex]
Femme_physics said:
Or delta y?
Yep! That's a good one too! :smile:
Uhh, no.
Mass is different from weight, which is a force.
It's not a conversion of units. These are different physical entities.
If you want to show the given value, you should write: W = 200 N.
Hmm, not sure I understand your question.
What you have is that mass is always positive.
Acceleration is a vector that you represent by a value.
That value can be positive or negative, but if it's negative that means that the acceleration vector is actually opposite to the direction you've drawn it.
  • #57
I did fix my sum of all forces = ma shortly after I made that post, and realized my error, thanks :)
Uhh, no.
I do realize mass is different than weight. Wait, I'm confused. Can we say that while you're obviously always right you can let me off the hook this time on the basis of "not super relevant" as the other stuff I'm not knowing atm?
I see. Let me see how it applies on other problems. Thanks :)
  • #58
I don't understand this question either. :redface:
The RHS of Ftotal = ma is always ma (not -ma). :smile:
  • #59
Fair enough! :)
Thanks tiny-tim, ILS! my heroes :)
I'll scan my full solution with ALL the corrections in the evening
  • #60
Let you off the hook? Let you off the hook?
I'm trying to get you hooked! :smile:
But oh well, if you really want to be off the hook, we can let it go as being "not super relevant".
Especially in an engineering environment where most people are not nitpickers. :)
Engineers usually just want the results. :rolleyes:
Just do better in the future! o:)
15K
9K
