1. Not finding help here? Sign up for a free 30min tutor trial with Chegg Tutors
Uniform Circular Motion
  1. Sep 6, 2009 #1
    A particle of mass m=1kg moves counterclockwise in a horizontal circle of radius r=1m with uniform speed of 1 m/s. Determine the velocity, acceleration, total force and the component of the the total force on the particle in direction of its velocity as a function of the angle.
    2. Relevant equations
    a = v*v / r
    F=ma
    3. The attempt at a solution
    Velocity = - 1 m/s
    (negative sign is to indicate the direction of the particle moving counterclockwise)
    Acceleration, a = 1
    Total force,F = 1N
    Is there anyone can help me to confirm my answer? Especially the velocity....
  3. Sep 6, 2009 #2
    Doc Al
    Staff: Mentor
    Velocity, acceleration, and force are all vectors. You must specify their direction as a function of angle. (I would use unit vectors and some trig functions.)
  4. Sep 6, 2009 #3
    Redbelly98
    Staff Emeritus
    I'm not familiar with using negative values to express the counterclockwise direction, is that a convention your professor said to use? It may be that just saying "1 m/s, counterclockwise" could be sufficient.
    Your values for a and F are correct, but you are probably expected to indicate their direction as well.
    EDIT: ahh, Doc Al responded faster than I.
  5. Sep 6, 2009 #4
    Thanks for the comments! I will try again ^.^
  6. Sep 6, 2009 #5
    Shouldn't you express the velocity in terms of rad/s since the last part say express as a function of the angle? If that is the case then acceleration would have to change too?
  7. Sep 6, 2009 #6
    Doc Al
    Staff: Mentor
    They are asking about linear velocity (the tangential velocity) not angular velocity.
Similar Discussions: Uniform Circular Motion
Loading...
