Homework Help: Uniform Circular Motion
  1. Jun 11, 2013 #1
    In uniform circular motion only a radial component of acceleration is present i.e centripetal acceleration. So why doesn't the particle following uniform circular motion go radially inwards due to radial acceleration?
  3. Jun 11, 2013 #2
    Acceleration is rate of change of velocity.Velocity is a vector.A change could be due to change in magnitude or change in direction.In uniform circular motion ,only the direction of velocity changes .This centripetal acceleration is responsible for change in the direction of velocity of the object .
    To be more clear,draw a velocity vector at time t ,then draw a velocity vector at time t+Δt .See where the difference of the two vectors point .
    One thing more,centripetal force mv2/r is not an individual force acting on the object,rather it is the net force acting on the object moving in a circle .It is the same thing as ma in F=ma equation .
  4. Jun 11, 2013 #3
    I mean to say that if the net force of the particle is radially inward then why doesn't the particle move radially inwards? Thanks for the previous reply though :)
  5. Jun 11, 2013 #4
    Lets draw a rough sketch.First draw a circle.Then draw a velocity vector(tangential) at time t.Add acceleration vector(radial).Where do you see the resultant velocity? Is it towards the centre or somewhere tangential to the circle ?
  6. Jun 11, 2013 #5
    Sorry to pinpoint, but how can we add acceleration vector to velocity vector? Isn't vector addition of only like quantities allowed?
  7. Jun 11, 2013 #6
    Sorry...I should have been more precise .By adding acceleration ,i meant acceleration times time which has the same dimensions as that of velocity .
    You must have encountered the first equation of motion v=u+at. It is a vector equation.
  8. Jun 11, 2013 #7
    CAF123
    What we have is: $$\mathbf{a}(t) = \frac{\mathbf{v_f}(t + \Delta t) - \mathbf{v_i}(t)}{\Delta t} \Rightarrow \mathbf{v_f}(t + \Delta t) = \mathbf{a}(t) \Delta t + \mathbf{v_i}(t)$$
    So to get the velocity vector at time t + Δt, take the initial velocity vector at t and do a vector sum with the acceleration vector at t multiplied by some scaling factor (which has the correct dimensions, so as to make the eqn sensible).
  9. Jun 11, 2013 #8
    Referring to other situations of motion
    Maybe I haven't understood something what you're trying to say..Ok..so in the equation v=u+at..'t' is 'Δt', 'u' is velocity of the particle 'Δt' time before the time when its velocity is 'v'..'a' is the constant centripetal acceleration..this equation just gives us the direction of vector v by adding vector u to vector at...mathematically as:
    [itex]\vec{v}[/itex]=[itex]\vec{u}[/itex]+[itex]\vec{a}[/itex]Δt..so we just get the direction of [itex]\vec{v}[/itex]...how does that tell us where is the particle going to move now? Would it be that particle's direction of motion would be the same as the direction of [itex]\vec{v}[/itex] i.e tangentially? Then it would try to move tangentially at every point but will not as the velocity keeps changing direction? But this is the same as saying that if we throw a ball upwards it would keep going upwards because of the direction of its velocity which is not the case as particle eventually goes in the direction of the net acceleration which is towards the earth..so even if the velocity as you are saying is tangential still the net acceleration is radially inward and so is the net force...So what's with this circular motion case?
  10. Jun 11, 2013 #9
    Imagine for a second that a particle could continue tangentially. Clearly its radial distance would increase infinitely. But that does not happen because at every instant it gets pulled radially inward.
  11. Jun 11, 2013 #10
    Ok..Thanks!
  12. Jun 11, 2013 #11
    rcgldr
    By definition, if the particle is uniform circular motion, then it's combination of speed and acceleration result in a circular path.
    With only centripetal acceleration, you can create just about any path, circle, ellipse, parabola, hyperbola, sine wave, ... . For example the path a car takes on a twisty road while traveling at constant speed.
Have something to add?
Draft saved Draft deleted
Loading...
