Homework Help: Uniform circular motion
  1. May 13, 2015 #1
    An object is moving uniformly in circles with a radius of 5m and a frequency of 2 Hz. What is its instantaneous velocity?
    2. Relevant equations
    3. The attempt at a solution
    The problem i am dealing with is the frecuency.
    I am not here for an answer or to cheat. I am applying for a admission test and working on some old admission test that comes without a answer sheet. Please help me to understand the way to solve this problem so i can pratice further. Thank you
  3. May 13, 2015 #2
    SteamKing
    Staff Emeritus
    You should understand that the hertz (Hz) is a unit of frequency equal to one cycle per second.
  4. May 13, 2015 #3
    Doc Al
    Staff: Mentor
    How does frequency (which is given) relate to period (T)?
  5. May 13, 2015 #4
    So if 1hz i 360 degrees (5m) than 2hz is 10m. hz is by second so that means that the velocity is 10m/s, right?
  6. May 13, 2015 #5
    Doc Al, i dont know.. I cannot aford a teacher thats why im using methods like this to learn.. Instead behaving like that give me a chance or a clue like Steamking did..
  7. May 13, 2015 #6
    Doc Al
    Staff: Mentor
    No. 5 m is the radius of the circle here.
  8. May 13, 2015 #7
    Doc Al
    Staff: Mentor
    You have Google at your fingertips!
  9. May 13, 2015 #8
    Okey i think i got it. O=3.14x10= 31.4m.
    1hz: 31,4m
    2hz: 1hzx2=31,4x2=62,8m/s ?
  10. May 13, 2015 #9
    Doc Al
    Staff: Mentor
    Good!
    FYI: Frequency and period are inverses of each other. Frequency is cycles per second; Period is seconds per cycle. So a frequency of 2 Hz, means a period of 1/2 seconds.
  11. May 13, 2015 #10
    Thank you! And thank you for your time and your advice, i will keep that in mind!
    The same goes for you too steamking!
Have something to add?
Draft saved Draft deleted
