When Does the Collection Approach Zero Uniformly for Differentiable Functions?
In summary, the function f is uniformly differentiable if and only if the function f' is uniformly continuous.
jostpuur
2,116
Let [tex]f:]a,b[\to\mathbb{R}[/tex] be a differentiable function. For each fixed [tex]x\in ]a,b[[/tex], we can define a function
[tex]
\epsilon_x: D_x\to\mathbb{R},\quad\quad \epsilon_x(u) = \frac{f(x+u) - f(x)}{u} \;-\; f'(x)
[/tex]
where
[tex]
D_x = \{u\in\mathbb{R}\backslash\{0\}\;|\; a < x+u < b\}.
[/tex]
Now we have [tex]\epsilon_x(u)\to 0[/tex] when [tex]u\to 0[/tex] for all [tex]x[/tex], but let us then define a following collection of functions for all [tex]|u|<b-a[/tex].
[tex]
\epsilon_u:E_u\to\mathbb{R},\quad\quad \epsilon_u(x) = \epsilon_x(u)
[/tex]
where
[tex]
E_u = \{x\in ]a,b[\;|\; a < x + u < b\}.
[/tex]
For all [tex]\delta > 0 [/tex] there exists [tex]U>0[/tex] so that [tex]]a+\delta, b-\delta[\subset E_u[/tex] when [tex]|u| < U[/tex]. So now it makes sense to ask, that under which conditions does the collection [tex]\epsilon_u|_{]a+\delta, b-\delta[}[/tex] approach zero uniformly when [tex]u\to 0[/tex], for all [tex]\delta > 0 [/tex]?
For example, could f being continuously differentiable be enough?
This thread is reasonably recent, so I thought I might reiterate your question. I was looking for conditions for which uniform differentiability holds and I found your thread as a Google search result. Have you found what you're looking for?
Actually it happened, that one guy did try to explain this to me, and the result seemed to be that uniform differentiability is very common. It could be that continuous differentiability is sufficient (or then I remembered incorrectly. In the next post I needed continuity of the second derivative). Unfortunately I was too tired and not so interested at that moment, so I didn't listen to that guy back then... :biggrin: Perhaps I should to try to return to this now...
It could be I proved now that if [itex]f''[/itex] exists and is continuous, then [itex]f[/itex] is uniformly differentiable. From the mean value theorem it follows that we have some mapping
[tex]
\{(x,u)\in\mathbb{R}^2\;|\; u\neq 0,\; a<x<b,\; a<x+u<b\},\quad (x,u)\mapsto \xi_{x,u}
[/tex]
such that
[tex]
|\xi_{x,u} - x| \leq u
[/tex]
and
[tex]
\frac{f(x+u)-f(x)}{u} = f'(\xi_{x,u}).
[/tex]
So
[tex]
|\epsilon_u(x)| = |f'(\xi_{x,u}) - f'(x)| \leq \Big|\frac{f'(\xi_{x,u}) - f'(x)}{\xi_{x,u} - x}\Big| \;|u|
[/tex]
If [itex]f''[/itex] is continuous, then by using mean value theorem again, we obtain some upper bound [itex]M[/itex] such that
[tex]
\Big|\frac{f'(\xi_{x,u}) - f'(x)}{\xi_{x,u} - x}\Big| < M
[/tex]
for all [itex]x,\xi_{x,u}\in[a+\frac{\delta}{2},b-\frac{\delta}{2}][/itex]. This condition follows when [itex]x\in [a+\delta, b-\delta][/itex] and [itex]u\in ]-\frac{\delta}{2},0[\;\cup\; ]0,\frac{\delta}{2}[[/itex]. Then
[tex]
|\epsilon_u(x)| < M\;|u|
[/tex]
for all [itex]x\in [a+\delta, b-\delta][/itex] and relevant [itex]u[/itex].
JinM, if you were interested in this, perhaps you can check the proof for mistakes? :wink:
Nice. I like your result -- your notation in the original post is foreign to me though, so I have to dig into that to check your proof -- although I'm sure its fine. :)
I also made a little bit of research, and another interesting result dictates loosely that f is uniformly differentiable iff f' is uniformly continuous; f is a differentiable function by assumption, of course. The proof follows easily -- thought I'd share this.
What is uniform differentiability?
Uniform differentiability is a property of a function that means its derivative is continuous and uniformly bounded. This means that the rate of change of the function is smooth and the magnitude of the change is not too large.
Why is uniform differentiability important?
Uniform differentiability is important because it guarantees that a function is well-behaved and has a smooth rate of change. This makes it easier to analyze and work with in mathematical and scientific applications.
How is uniform differentiability different from ordinary differentiability?
Uniform differentiability is a stronger condition than ordinary differentiability. While both require the derivative to exist, uniform differentiability also requires the derivative to be continuous and uniformly bounded. This means that ordinary differentiability is a subset of uniform differentiability.
What are some examples of uniformly differentiable functions?
Some examples of uniformly differentiable functions include polynomials, exponential functions, and trigonometric functions. These functions have continuous and bounded derivatives, making them well-behaved and easy to work with.
Can a function be uniformly differentiable but not differentiable?
No, a function cannot be uniformly differentiable but not differentiable. Since uniform differentiability requires the derivative to exist, a function must first be differentiable in order to be uniformly differentiable.
  • Calculus
