Unique flying machines
  • Thread starter wolram
wolram
Dearly Missed
4,397
559
Lifting bodies and flying saucers, are they aerodynamic or have properties
that are worth pursuing?
Answers and Replies
FredGarvin
Lifting bodies are most definitely a highly researched area in aerodynamics. The space shuttle is the most widely known lifting body aircraft today. NASA did a lot of lifting body work in the X series aircraft back in the '60s. The latest concepts for the hypersonic transports and future aircraft are all lifting bodies as well.
I don't think the flying saucer has any hope in our current technology. A couple of programs did look into it though.
russ_watters
Mentor
21,855
8,822
expansion: Hypersonic aircraft research is focusing on lifting bodies because of heat issues. On a plane with sharp edges, the shock wave is touching the aircraft and heat builds up there. Lifting bodies are blunt and create an insulating cushion of air between themselves and their shock wave. They literally ride their own shock wave (some have been called "waveriders").
Ivan Seeking
Staff Emeritus
1,004
Either Buzz Aldrin or Gordon Cooper once commented that a saucer shaped craft wouldn't create a sonic boom. I have no idea is correct or not, but apparently it was thought to be true at one time.
russ_watters
Mentor
21,855
8,822
The way I understand it, the shock wave around a lifting body is curved, not sharp like on an angular aircraft and that causes the shock wave to be less concentrated and dissipate faster. And I guess with no nose at all, a saucer would have an even more irregular shock wave.
quark
231
It was observed that it was easier(actually the power required is lesser) to overcome gravitation by rotary motion when compared to thrust. The shape of flying saucers may have the reason of similar kind. If the top and bottom surfaces are designed aerodynamically and with rotary motion, the air resistance can be minimized.
Having said that, I confess I didn't make indepth study of the science. I often wonder them as the time machines of our future folks :tongue2:
wolram
Dearly Missed
4,397
559
Would a flying saucer be a lifting body? i have seen some wacky ideas to
make them fly.
Clausius2
Just a comment. The last models of X series I've seen were not blunt nosed. It seems that blunt nose design is not the current way of making it better.... I don't know why.
FredGarvin
The most roundest lifting body I can think of was the X-24:
http://users.dbscorp.net/jmustain/X-24a.jpg [Broken]
wolram
Dearly Missed
4,397
559
Now that was a strange looking bird, if its what i recall, twin engined prop almost circular body?
FredGarvin
Nope. She was a bath tub shaped lifting body that had a rocket. This, believe it or not, was the great great great great great grandfather of the space shuttle.
yourdadonapogostick
270
she was the great great great great great grandfather of the space shuttle?
enigma
Staff Emeritus
Looks a lot like the X-38, IMO.
Lifting bodies will be used for any re-entry vehicle where you want or need to limit the g-loading on the passengers or cargo.
sid_galt
502
Assuming mach numbers of 10 and small deflection angles (angles of top or bottom surfaces witht the chord) like 20 degrees, the temperature rise is 4-5 times the ambient.
My book here says that providing best air compression to the scramjet is an essential consideration of the design.
Granted that the temperature 4-5 times the ambient would be quite high, given that these things operate at high altitudes where temperatures are low, I'll say temperature is not an overwhelming consideration.
FredGarvin
Point taken! Good catch.
Danger
253
For shame, Fred! A fellow Avro fan failed to mention http://www.virtuallystrange.net/ufo/mufonontario/avro/avrocar.html? :tongue:
FredGarvin
I never thought that the Avro Car was an actual lifting body. Was it supposed to be? I'm going to have to check in on that one!
FredGarvin
That's a cool link Ivan. How do you find that stuff?
Ivan Seeking
Staff Emeritus
1,004
"Mainstream" UFO literature.
There are a few sites that are quite reliable.
Suggested for: Unique flying machines
  • Last Post
Automotive Flying Hypercars?
  • Last Post
  • Last Post
  • Last Post
