Unit conversions
  • Thread starter smray7
water flows into a tube with a diameter of 6.35 cm at 0.012 meters cubed per sec.
it exits the nozzle with a diameter of 2.2cm at what speed?
a = pi r squared
A1V1 = A2V2
My question is should i convert the cm to meters?
how do you know when to do unit conversions?
Answers and Replies
danago
a = pi r squared
A1V1 = A2V2
In this case it will not matter. In general, an equation is only correct if the units are the same on both sides of the equality sign.
If you use area A1 in cm2 and velocity in m/s, the left hand side will have units of cm2 m/s. This will be equivalent to the right hand side if you also use cm2 for A2.
Another way to think about it is if you rearrange the continuity equation you get:
[tex]\frac{A_1}{A_2} = \frac{V_2}{V_1}[/tex]
i.e. the ratio of outlet velocity to inlet velocity is equal to the ratio of inlet area to outlet area. Since we are talking about a ratio of areas, it really does not matter what the units are, as long as they are the same.
ok thanks, that's clears things a little. on another problem i have to determine the pressure on wing two.
airplane mass: 1.60 x 10^4
wing one area : 40m^2
wing two area : 40m^2
pressure on wing one : 7.00 x 10^4
pressure on wing 2: ?
F= PA
mg = P1A1 + P2A2
mg = A(P1 + P2)
mg -P1
_______ = P2
A
so anyhow i have some number and the unit as:
(#kg)(#m/s) - (#Pa)
_______________
#meters squared
i know pressure is measured in Pascals, but when all is said and done, none of the units cancel. does that matter?
Recheck your algebra and your unit for g... the units work out fine.
You will get X pascals = P2
Related Threads on Unit conversions
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
