Units problem
  • Thread starter nate92488
I have this problem I just can't figure out.
Current = A (Ampere)
i(t)=z(e^t/(RC))
where z is the initial current at t=0, R is the resistance in Ohms and C is the capacitance expressed in secondary units as F (Farad)
- Express the units of F in terms of seconds and ohms
So, this is what I tried to do, tell me where I went wrong
A = A e^(s/F-Ohms)
1 = e^(s/F-Ohms)
ln(1) = s/F-Ohms
0 = s/F-Ohms
F = 0
I obviously did something wrong, so any help would be apreciated, thank you!
Answers and Replies
If you think of an RC circuit as a second order differential equation you will see
dQ/dT + 1/(R*C)*Q = Junk
Where junk = 0 for a loop of a circuit without any external components. Otherwise it can also be some forcing function driven by batteries, power sources, etc. But anyways, Q is the charge here so...
dQ/dT = charge/time (amps)
thus Q*1/(R*C) = charge/time since Q = charge, R*C has dimension [T]
Thus an Ohm-Farad has dimension [T] and the quantity in the exponent in your equation is dimensionless then - as it should be
thank you, I got it now.
Related Threads on Units problem
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
