Calculating Solar Energy Needed to Power US
In summary, the average American uses 1.5 kilowatts of electrical energy and solar energy reaches Earth's surface at an average rate of 300 watts per square meter. To provide all of the United States' electrical energy, we would need to cover 0.055% of the country's land area with solar cells, assuming they are 20% efficient at converting sunlight to electricity.
frasifrasi
276
The average American uses electrical energy at the rate of about 1.5 kilowatts . Solar energy reaches Earth's surface at an average rate of about 300 watts on every square meter.What fraction of the United States' land area would have to be covered with solar cells to provide all of our electrical energy? Assume the cells are 20% efficient at converting sunlight to electricity.
this is from the first chapter on units. Don't I need the us's size and population for this? Can anyone give me hints on how to get the answer?
You know how much electrical power is needed to power the US- 1.5kW per person.
So, we need enough solar cells to collect enough energy from the sun to produce 1.5kW *(US Population).
HINT:
Let's assume we have one square meter of land covered in solar cells. How much power does the light hitting those cells carry? How much of that power is actually converted to electrical power by the solar cells?
I convert 1.5 to 1500 W. So, 20% of 300 is 60 W/SQ m. SO, the light converted is 60W.
what is the next step?
I think you do - at least an average population density.
Regards,
Bill
You'r quite right. So, how can you find the population and land area?
I think you'll have to look them up if they don't give them to you. You can't compute them.
So, OP, where would you look for this?
I looked it up but the calculations got very large.
Basically, I multiplied the population by 1500W to get the total energy needed. Than got 20% of 300W = 60W. Now, I divided the total energy by 60 to get the rerritory needed. then, I divided the total landmass by this number, did I do the right calculations?
Ps. I googled it.
Sorry, mistaken identity. I thought you were the OP and the mistake seems to be mutual. Sorry again.
Ps. I googled it.
Those are the right calculations.
so, just for confirmation, dividing [big number of people X 1500w]/60W/m will give you the number of meters needed to be covered with solar panels right? I am very trepid when it comes to units.
PS. I aced the calc II final last semester (If any of you remember I was asking about 10 questions a day and getting berated, but it was worth it--I beat ~678 students)--thank you everyone.
Since this is a units class, it might be worth while to point out that using population density (e.g. [itex] \frac{people}{kilometer^2} [/itex] should give the same answer.
[tex] \frac{person}{area\_available} * \frac{energy}{person} * \frac{area\_used}{energy} = \frac{area\_used}{area\_available}[/tex]
Regards,
Bill
[P.S. "person"=1 "people"=?]
I just wanted a direct confirmation of my last question, can anyone please verify it?
As for your suggestion, what is area available (the total landmass?) and which value is "energy"? what about area used?
area_available=total_area/(# of people) <-each person gets the same area
I think Dick already answered your question, but you may want to re-write the process more clearly. I can't tell from what you wrote if you used the same units of area for both landmass and solar panels.
Regards,
Bill
I used m^2 for total area and m for solar panels, which canceled to give me m. is this correct?
no - both should be units of area (m^2)
note: "square meter"=m^2
your answer should have no units - they should all cancel in the case of a %
Regards,
Bill
how do I make m --> m^2 ?
regards.
just for the heck of it, would you mind working it out with the set up you proposed?
Population: 301,139,947
Area (Land): 9,161,923 SQ KM
This was an online homework and I already sent out the wrong submission (the right answer was . 06%), I just want to learn how to do this effectively once and for all.
Thank you.
regards.
Thank you.
The note I made in my last post should show you how to convert the m you used into the m^2 it should have been. Glance over the problem again to see why.
Since "the right answer" you show appears to be close enough, I'll take your word for having submitted this already. Here it goes:
[tex]\frac{301139947 person}{9161923000000m^2}*\frac{1000 W}{person}*\frac{m^2}{0.2*300W}=0.00055=0.055\%[/tex]
Do you follow what I did?
Regards,
Bill
Yes, I was able ti follow, but did you not use the fact the 1.5 kw is the average usage--I do not see 1500W anywhere in the solution. anyway, thank you for taking the time to help me with this, it is just that this one question was bothering me. Good night.
Good catch - I didn't transcribe the problem accurately, and by some coincidence calculated the "correct" answer you posted. The correct answer using your population/landmass should be 1.5 times as large (.055% *1.5=.082%).
The population density I get from your numbers checks out with a quick google of my own, so I don't see where a "correct" answer of .06% could come from.
Regards,
Bill
the next lowest answer was .6%, so i think that would be acceptable.
I am just curious, what is that 1000W/person term you have, I don't know what it means--is that what should have been 1500W?
Thanks and that is my final question! : )
I am just curious, what is that 1000W/person term you have, I don't know what it means.
That should be 1500W/person as you pointed out. It is the average usage. For example:
[tex]\frac{1500W}{person}=\frac{451709920500W}{301139947 person}[/tex]
Total energy over number of people equals average energy.
Regards,
Bill
What is solar energy?
Solar energy is energy from the sun that is harnessed through various technologies, such as solar panels, to generate electricity or heat. It is a renewable and clean source of energy that does not emit harmful pollutants.
How is solar energy calculated for the US?
The solar energy needed to power the US is calculated by considering various factors such as the average daily sunlight hours, the efficiency of solar panels, and the energy demand of the US. This calculation involves complex mathematical equations and can vary depending on location and time period.
What is the current percentage of US energy that comes from solar power?
As of 2021, solar energy accounts for about 2.3% of the total electricity generated in the US. This number is continuously increasing as more and more individuals and businesses are adopting solar energy as a primary source of power.
What are the benefits of using solar energy in the US?
There are numerous benefits to using solar energy in the US. Some of these include reducing carbon emissions and fighting climate change, creating jobs in the renewable energy sector, and reducing dependence on fossil fuels. Additionally, solar energy can also save individuals and businesses money on their electricity bills in the long run.
What are some challenges in using solar energy to power the US?
While solar energy has many benefits, there are also some challenges in using it to power the US. One major challenge is the initial cost of installing solar panels, which can be expensive. There is also the issue of storing excess energy for use during non-sunny days. Additionally, not all areas in the US receive the same amount of sunlight, making it difficult to implement solar energy on a large scale in some regions.
  • Electrical Engineering
  • Mechanical Engineering
