Universe Expanding: Space or Matter?
In summary, expanding space means that distances between things are increasing on sufficiently large scales.
Gear300
1,213
When it is referred that the Universe is expanding/accelerating outward, do they mean to say that space is expanding or that matter is accelerating outward through space?
Space news on Phys.org
The space itself is expanding, carrying the matter with it.
Since you can't observe space directly (you can only observe measuring sticks) , all the direct astronomical observations that we use to justify the statement "the universe is expanding" are based on light radiated by moving objects.
The primary theory behind the expansion of the universe is Einstein's General Relativity. In terms of the theory, it is space itself that is expanding, analogous to what would happen if our universe was a 2-d surface of a balloon and the balloon was expanding.
Therefore, if you believe General Relativity, then it is space itself that is expanding. If, however, you want to strictly limit ourselves to what we observe, we can only observe measuring sticks.
At a slightly more detailed level, here are two explanations for the cosmological redshift:
(1) Objects are moving away from us and so the frequency of emitted light is lower (redshifted). This is just like an ambulance moving away from you producing a lower tone from it's siren.
(2) In the time that the light has been traveling from the object, space has expanded , increasing the wavelength of the light, which decreases the frequency, leaving it redshifted.
In general relativity the answer is unambiguously (2). It turns out (1) and (2) predict different results, and (2) is the correct explanation of the cosmological redshift using general relativity.
I see (to the extent I can)...thanks for the replies. But since it is space that is expanding, does that still imply that we might experience relativistic effects, or do we need to be moving through space for that to happen?
There is no such thing as "moving through space" and no, there are no relativistic effects associated with expanding space. There are actually galaxies that appear to be moving faster than C.
Thanks for the answer.
russ_watters said:
There is no such thing as "moving through space"...
Then what is there?
I'm not totally sure what Russ is getting at, but from a spacetime perspective, moving through space without moving at all through time would correspond to infinite velocity, and that is impossible in relativity.
I see. Thanks again for the reply.
An additional question: if space is expanding, doesn't that necessarily imply that there should be a higher-dimensional medium for it to expand (thus, we have indirect evidence for higher dimensions)?
Gear300 said:
Then what is there?
Space is not an object nor an absolute reference frame, so there is nothing for one to measure a velocity relative to. Velocity is measured between objects.
Then what is space and what is meant by it expanding?
I think the notion that matter is "carried by" the expansion of space is a bit misleading. (Reply #2 above.)
I like this definition: space is that which is measured by rulers and clocks. This is the converse of Einstein's operational definition of time: that which is measured by clocks. Spacetime is that which is measured by rulers and clocks.
Expanding space means that distances between things are increasing. We speak of expansion of the universe because on sufficiently large scales, the distance between any two objects is increasing. Since everything is moving further from everything else (on sufficiently large scales) you can equally say that the space between everything (on sufficiently large scales) is increasing. But I think it may be slightly better to say that space is expanded by the motions of objects, rather than objects are carried by the expansion of space. It's a bit like noting that spacetime is curved by massive objects.
You can also say that volumes are increasing. If you try to define a volume for a region of space, on sufficiently large scales, that volume is increasing.
Cheers -- sylas
Yes, that's what one can say and usually does say.
The unambiguous meaning of it is that distances increase with time (with some subtleties concerning definitions and exact values). Every statement that goes beyond this fact, like space dragging objects with it or otherwise, is necessarily interpretation or mental picture, not fact. Interpreations may be useful or not, and one may pick in each event the one that is least misleading.
General relativity is not so easily understood as special relativity. GR forces you to divorce many principles of SR when you look at the big picture. SR is only a special case of GR. Does that help? Nothing in SR forbids an expanding universe. Pretty much everything in GR demands it. The speed of expansion is irrelevant.
Cheers -- sylas
From all this, it seems that there is no stable definition for motion...
If I'm right, SR implies that all motion is evaluated relative to some reference that is also evaluated relative to another reference and so on. So then, as Ich said, there isn't too much against this interpretation:
Still...if space is the one expanding...shouldn't it need to expand through a higher-dimensional medium and is that implied anywhere in GR or is it just interpretation?
No, there's no need and no implication for higher dimensions.
As for motion having no stable definition; I think it is more correct to say that when we describe things with conventional language or analogies, descriptions are incomplete. The maths of it is unambiguous. There are various ways you can measure a recession velocity, with different co-ordinates or distance definitions. If this is done with full rigour -- and this certainly can be done -- then there is no ambiguity about meanings or transformations between co-ordinates or alternative definitions.
Cheers -- sylas
I'd say Gear300 is correct: there is no undisputable definition of "motion" in GR, if the concerned objects are at some distance.
You know thar SR has no concept of absolute speed, there is only relative motion. That's true also in GR, so I don't like the idea of "motion through space" - even if it is useful for specific calculations, and even though it works generally and can be defined appropriately.
In GR, even relative velocity between distant objects depends on how you define it. Even worse, relative velocities are not easy to calculate, so it's common to take some coordinate values and call them velocity.
But, of course, if you pick one definition and stick to it, everything will work out mathematically.
'Space' only exists as a measure of the separation of 'objects'.
The measurement is determined relative to a 'standard' -- how this standard is chosen can vary.
The definition of an 'object' can vary.
My summation.
Exactly. This is what I meant when I spoke of using different co-ordinates and transformations.
The universe does not easily submit to human descriptions. All we know is it is really big.
In looking over the posts, in general, I think it presumptious to exclude some of the interpretations of space based upon what we think we know and what we know we don't know. Historically, Einstein premised his GR theory on the fact that the universe was static - and this was one of his primary arguments he used to criticize de Sitter's model - it wasn't static. GR is based upon the ad hoc postualate that inert matter affects static space - it really doesn't imply expansion per se. Then there are the statements by Einstein in his later years that embrace the notion of space as being more than just the distance between things - that it was a part of the universe that functioned in such a way as to make accelerated motion relative just as is inertial motion - that is, a reactionary force would be exerted upon a static mass if the entire universe (including its space) is accelerated, just as would be the case if the mass were accelerated relative to to the content of the universe.
Presently, the search is to find the energy needed to bring omega equal to one - and if this turns out to be hidden in the spatial stress or in the gravitational fields, then space cannot be relegated to nothing And as one one more point, the notion matter creation during inflation depends upon the energy released by an expanding negative pressure space.
In summary, I think it is good to keep some options open about what space could be - there seems to be a mainstream urgency to surpress interrogation in this regard
Who was it that said: "Cosmologists are frequently wrong, but never in doubt"
Arp is the short answer. Cosmologists are no less surprised than anyone else about the existence of dark energy. At present, there is no other viable explanation.
And I must comment, that I have NOT as yet seen ANY evidence for 'dark energy'. (and yes I have read the many papers on the subject -- not convinced -- data is far too poor)
Lev Landau. When he said this, there was a paucity of good cosmological data. The situation today is much different, as Weinberg indicates in the preface of his new cosmology book,
"The new excitement in cosmology came as if on cue for elementary particle physicists. By the 1980s the Standard Model of elementary particles and fields had become well established. Although significant theoretical and experimental work continued, there was now little contact between experiment and new theoretical ideas, and without this contact, particle physics lost much of its liveliness. Cosmology now offered the excitement that particle physicists had experienced in the 1960s and 1970s."
Correct George - Lev Landau - but I wonder if the statement should be thought of as appropriate only in the context of its historical utterance - perhaps it may be better classified as timeless.
There is definitely much new data - if we look back 20 years hence (if humanity lasts that long) I wonder if the recent discoveries will be viewed as pointing in the direction we presently interpret.
The Legacy Supernova Survey is the best and only significant observational evidence for dark energy. It is difficult to dispute. See
http://www.kqed.org/quest/blog/2008/04/08/supernova-legacy/
http://mr.caltech.edu/press_releases/12767
http://www.gemini.edu/create-content/pio-websplash/the-last-supernova-legacy-survey-spectrum
Science plods along like a turtle, Turtles live for a very long time, not unlike science done properly.
I've seen it. Worked with it for the last few years. I do DISPUTE that it shows anything like 'proof' for 'dark energy'. The so called 'acceleration' is ONLY seen when comparing to a known flawed model -- Milne or an empty model equivalent.
The departure 'curving' seen is due to the model, poor data quality, and poor data fitting techniques. Makes no difference whose name is attached to the paper.
Close analysis of the limited data does indicate a systematic divergence consistent with a slower CONSTANT expansion velocity than an empty model. This is considered to be a normal departure of comparing an 'empty' universe and one containing matter. THERE IS NO CHANGE. Its the same departure as seen in more redshifted data.
Flatly false. It is seeing in the fact that the rate of expansion is increasing rather than decreasing, as determined by the evidence. I have no idea how you can possibly claim to be "working" with this. Your answer doesn't make any sense at all. Prior to this evidence, the conventional model was a critical mass model; not the empty model.
No, it doesn't. The empty model would give a constant expansion rate. The evidence indicates that the rate is increasing.
Cheers -- sylas
Cheers -- sylas
Have you LOOKED at the simple image attachment to see what can happen with two slightly different data fits to data? And this assumes the data doesn't have a systemic error. It appears to have one in very low z -- (suspected that a small gravitational correction is needed). This only effects data below z<<0.2
The evidence is the data. Do your own analysis.
I looked at it, and it didn't seem to use the data at all.
People have said above that the "only" evidence for dark energy is the supernova light curves. That's not strictly true. As with all science, cosmology uses all the available evidence together. If you use supernova light curves and nothing else, you might consider the empty model as credible. The data does actually indicate acceleration, as I indicated, rather than merely constant expansion as in the empty model, but the difference is small.
But the empty model has worse problems than a slightly worse fit with the supernova data... and that is that the universe ISN'T empty. There are multiple lines of evidence for dark matter, on top of all the baryonic matter around... and worse, the universe is FLAT. Empty model can't give you that at all.
So, as I said before, it's just nonsense to say that acceleration only shows up by comparison with the empty model. It shows up much more strongly, in fact, when compared with other flat models, with critical mass density. Which, of course, was the preferred model before the evidence for dark energy came in, because the empty model is ruled out by other data.
The whole question remains open, particularly in the light of the fact we don't really know what dark energy or dark matter really is. But it's just silly to say that acceleration is only apparent in comparison with the empty model.
If you REALLY want to look at data, then you need to look at the observation; not just the curves you provided for some of the models from some spreadsheet (I presume). You don't seem to be doing "data analysis" at all.
Here's a better way to look at data. I am simply giving some figures from New Constraints on ΩM, ΩΛ, and w from an Independent Set of Eleven High-Redshift Supernovae Observed with HST, by Kopp et al (2003) at astro-ph/0309368.
This is a comparison of magnitudes with redshift.
The thing to note here is the cosmologies. The lowest line is the critical mass case. The middle line is the sub-critical mass. The upper line is a dark energy. The empty model would be between the middle and upper lines, but it is not displayed here. As you've noted yourself, this is a falsified model in any case. Why would you bother to show it?
The fact is, the empty model... on THIS data... would be hard to separate from the dark energy model. But that ISN'T the right comparison. And it most definitely is not the case that the dark energy model only shows up by comparison with the flawed empty model! Dark energy actually shows up BETTER by comparison with the critical matter model... which is not flawed... at least, until the data for dark energy came along.
I don't mind if you are personally skeptical on your own behalf. The major objection I had was your claim that dark energy only shows up when comparing with the empty model. That's just silly.
My own position is that I don't think the case is closed. Dark energy is able to explain the data best, at present; and more recent data has only strengthened that case. But until we know more about what dark energy actually is, I'm keeping an open mind.
Cheers -- sylas
Cheers -- sylas
I see a bunch of data -- but NOTHING that supports 'acceleration' without using a model for reference. THAT is the point. Further, there are other models that do NOT show acceleration using the same data. So that it seems to me that the model needs to be proved -- somehow -- independent of the data showing these departures -- BEFORE we invent entirely new kinds of energy just to protect a cherished model.
Frankly, the concept that matter density -- critical or otherwise -- having much to do with the expansion of the universe is also an question.
Sorry, a thunderstorm here and uploads were interrupted.
Attached in the thumbnails are three comparisons plots of the common format used to show acceleration (data from Ned Wrights Cosmology page).
The first is basically a reproduction of the typically shown support for dark energy.
The second is a comparison of empty models using Milne as reference. This indicates a possible problem with Milne -- in that the other empty model 'curves' to fit the data.
The third is a similar to the first plot BUT the reference is the SGM Empty model -- for the data and the curve ('full matter' model) fit. Note, NO HUMP .. and no apparent acceleration.
I'm NOT presenting this the tout a model. That is not the point. The point is the apparent acceleration is due to the functional structure of the Standard Model (mirrored by Milne at Omega=0). By itself it doesn't prove its wrong -- but it also doesn't prove it right.
The ONLY support I have seen for dark energy -- related to acceleration -- is when using Standard Model. There is NO model independent support for this. And that is my problem with it.
Note, the SGM model while relatively simple -- as it was designed to be -- still is far to numerically challenging for a spreadsheet (NEVER use them).
I have a MSC in Engineering Physics and have been doing data analysis for over forty years professionally. So far the claims I've seen (for dark energy) are not supported by the data I've seen.
  • #31
That's just silly. Data is ALWAYS considered in the light of completing models. Without that, it is just numbers. OF COURSE you can't support ANYTHING if you don't actual check data against models. It's okay to be skeptical, but this is just refusing to look.
Your problem is that you weren't even looking at data as far as we could see in your diagram. You evidently have some strong intuitions about what models you are willing to consider, but there's no sign you are willing or able to test those intuitions against data, which is the meat of of how science works.
The models are the lines in the diagrams I provided. I already explained that an empty model does fit this data set tolerably well -- not as well as the dark energy model, but still pretty good. But we BOTH know that this empty model is falsified already. You even said it yourself just above!
You've completely ignored the specific criticism I gave of your comment... you said evidence for dark energy and accelerating expansion only shows up by comparison with the empty universe model. That's flatly false, as I noted previously.
The talk of "proved" is just failing to understand science. We don't "prove" models like theorems. We check them against data. Which is PRECISELY what I am showing in the diagram, and why people were forced into considering dark energy.
The notion of a "cherished" model is more foolishness. In fact, dark energy was a radically surprising idea; not a cherished model at all. Unless, of course, you mean that the new ideas had to preserve "cherished models" like general relativity. Sheesh.
Anyone is welcome to come up with new models that explain the data -- all of it -- better. Nor is that beyond the bounds of possibility. But so far, the evidence points towards dark energy. It's not proved, but it has a credible case, and so far fits the data better than anything else.
A pretty silly one, frankly; this just goes from bad to worse.
But back to the general questions of the thread...
Another paper that is worth looking at is Constraints on Dark Energy from Supernovae, Gamma Ray Bursts, Acoustic Oscillations, Nucleosynthesis and Large Scale Structure and the Hubble constant by Ned Wright, at astro-ph/0701584.
It looks at a range of data and models, include data from greater redshifts than really makes empty universe drop out of contention. One of the models considered is an "evolving supernova" model, in which changes in high redshift supernova are taken as changes in the nature of supernovae over time. This proposal has problems also, but its another idea people are considering.
Cheers -- sylas
PS. Added in edit. I wrote this in response to the first edition of your post. Now you seem to be using the data, but thanks all the same... I'll stick with Ned's account of the matter. The substance seen in this thread does not live up to the standard you are trying to claim by virtue of credentials.
  • #32
The 'cherished' model was not just 'dark energy' -- Dark energy is no more than a 'tack on' to the Standard Model formulation. The Model I'm objecting to is the Standard Model -- and the way General Relativity has been USED to support it.
But what I'm objecting to even more is this tendency I see in cosmology to generate 'bizarre science' to fix a failing model. The current Standard Model is a monstrosity.
It seems to include just about everything someone can attach to it. There is no way to be critical of a part of it without being force to take it on wholesale.
This is NOT the way science should be done. Keep the hypothesis limited to single or at least limited issues -- and check those out. Don't lock down 'the answer' in mathematical 'smoke' in an attempt to confuse the opposition.
I'll say again -- IF the universe is flat -- spatial dimensions not curved, then the
possible options (to me) seem to be:
1) General Relativity is not needed to describe the large scale of the universe.
2) Or we live in an amazing coincidense of a universe that just by 'luck' happens
to be flat. This 'luck' having names like dark matter (exotic) and dark energy.
  • #33
Well, I've given some specifics of where your criticisms went from skepticism to outright misrepresentation or misunderstanding of the models.
I also think you are completely incorrect about this being the wrong way to do science; in fact it has been very much the reverse. Cosmology has been progressing and developing and changing precisely because it has become much more an experimental and observation based science. That's going to continue, with new experiments coming up to test the competing ideas. For example, there's the proposed Supernova Acceleration Probe. This will be a strong test of the dark energy hypothesis. If selected, it could be launched next decade.
The idea that science should deliberately limit hypotheses is about as wrong as wrong can be. Dark energy is not sacrosanct. Anyone is welcome to propose and explore new ideas: I mentioned the "evolving supernova" proposal. You can object all you like, but to imagine that you are supporting science by trying to disallow hypotheses based on some intuition you appear to have about what is permissible is so completely counter to how science works that I am actually quite stunned.
By all means take on the current leading models wholesale! Go hard... that's how we develop new insights. But you are going to have to do that with empirical evidence and alternatives that match the data. Not just ruling what you don't like out of bounds, with subjective notions of what you consider "bizarre", or "monstrous", or by just labeling a model you don't like for some reason as "lucky". (What the heck was THAT about?) There's lots about the world which has turned out to be "bizarre" and counter to intuitions. Being open to what seem initially unintuitive is just about a necessary precondition for working in science.
I am pretty certain, frankly, that we are due for some surprises and upsets in physics over the next decade or two, in work on cosmology and fundamental physics. But I expect to progress to come from people who are more willing to go with data, rather than preconceived ideas of what is permissible.
Cheers -- sylas
  • #34
Good Post - I have always had doubts about sewing together so many ad hocs to make the model viable - of course, as Feynman suggested, there is no guarantee the universe will turn out to be mathematically beautiful or simple.
But at present the data does not seem to be sufficiently compelling as to justify conclusion
  • #35
We are indeed sorely lacking in good data. And it appears that the data we do have are acquired based on the need to support particular a theory. No problem with that per se, but there can be a problem when a single model is 'driving' the interpretation of that data.
The monolithic nature that the Standard Model has become nearly always results in demands for any questioner on a single part that might reflect on the basic model be required to support his idea in so many diverse fields of knowledge that it is impossible for an individual or small group to meet.
Too many people have their entire careers and lives invested in the Standard Model for anything to change in the short term.
Time -- and good data -- will tell.
1. What is the evidence for the universe expanding?
One of the key pieces of evidence for the universe expanding is the observation of redshift in the light from distant galaxies. This indicates that the galaxies are moving away from us, and the further away they are, the faster they are moving. This is consistent with the idea of an expanding universe.
2. Is the universe expanding into something?
No, the universe is not expanding into anything. The concept of the universe expanding refers to the expansion of space itself, rather than the expansion of matter into pre-existing space. The universe is infinite and does not have a boundary or edge.
3. Is the expansion of the universe accelerating?
Yes, the expansion of the universe is accelerating. This was first discovered through observations of distant supernovae in the late 1990s. The current leading explanation for this acceleration is the presence of dark energy, a mysterious force that is causing the expansion to speed up.
4. Will the universe continue to expand forever?
Based on current observations and models, it is likely that the universe will continue to expand forever. However, the rate of expansion may change over time and there are still many unknowns about the future of the universe.
5. How does the expansion of the universe affect the size of galaxies and other structures?
The expansion of the universe does not directly affect the size of galaxies and other structures. This is because the force of gravity is stronger than the expansion, so it can counteract the stretching of space on smaller scales. However, over very large distances, the expansion can cause the separation of galaxies and the formation of new structures.
  • Cosmology
