Unknown angle in equilibrium
  • Thread starter Karstedt
Karstedt
Trying to find angle u of bars (symmetrical) with ground at equilibrium under load.
Two bars, negligible weight of length .4m
Spring at midpoint k = 3kN/m, unstretched when bars at 45 deg
F = 150N, 5 deg
W of block 10kg
Slope of ground under block 5 deg
coef friction = .2
Fx = 0 = Ax + 150sin5 - Nsin5 - .2Ncos5
Fy = 0 = Ay - 150cos5 + Ncos5 - .2Nsin5
Ma = 0 = 150cos5*.4cosu + 150sin5*.4sinu - Ncos5*.8cosu + .2Nsin5*.8cosu
4 unknowns, Ax, Ay, u, N.... this course doesn't include indeterminate structures so I tried anyway. Since I could not get an answer via the standard eq equations I tried to eliminate a variable first in the whole structure then by doing a FBD of the block. I got N in terms of u but it still doesn't work anything out. It's incredibly messy using the block FBD and I re-did it several times because I kept finding errors but I eventually got to a quadratic of tan(u) that spit out ~56.1 deg. which is the closest thing to a reasonable value I've gotten, but that value doesn't seem to work when I run with it. I tried to find a trig identity that would simplify things, but can not work anything out.
Answers and Replies
NascentOxygen
Staff Emeritus
1,073
That 45°, is it relative to the other bar or relative to the vertical?
Karstedt
It's relative to the horizontal actually.... but at 45 that's the same as vertical. The angles of both bars relative to the horizontal ground.
Suggested for: Unknown angle in equilibrium
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
