fatcat39
- 40
Someone actually posted this exact problem 4 months ago, but here it is. There wasn't an answer.
Heron of Alexandria invented the steam jet engine in the first century A.D. One of his many inventions, the one shown below was invented for amusement but employs many concepts not again used until the 18th century.
A caldron with water in it was heated by fire and the steam generated was fed up and into a hollow spherical container with two spouts on each side. The exiting steam would spin the container at high speeds. We want to estimate the highest rotational speed using the little facts we have about this ingenious device developed almost two thousand years before it was rediscovered as the steam engine.
The spherical container has a radius of 0.2 m and mass of 10 kg. The two spouts can be considered massless but extend an additional 0.1 m above the surface of the container. The container is hollow and do not consider the moment of inertia of the steam contained inside.
b) If the pressure inside of the container reaches 1.5 atmospheres what is the angular acceleration of the container? Take the area of the spouts to be circles of radius 0.01 m. (Remember that the outside pressure is 1 atmosphere).
I know Force = Pressure*Area, but since steam is coming out of the container to push the sphere around, should I calculate force as Force = (1.5 atm + 1atm) * area or just Force = 1.5atm * area. Then from there, I calculate torque and moment of inertia to calculate angular acceleration.
Okay, so the moment of inertia is just (2/3)MR^2, I think, because the two rods are essentially massless and have no bearing on I, right?
B) Pressure is Force/Area, so therefore, Force = Pressure * Area. The pressure is 1.5 atm - 1 atm, so 0.5 atm. But is the area the radius of the two spouts? or the volume of the entire sphere?
Thanks in advance.
Thanks in advance.
