Urgent: de Brogile wavelengths of atoms, working in eV!
  • Thread starter Lavace
Lavace
62
http://www.strings.ph.qmul.ac.uk/~russo/QP/r06QPHYEX.pdf [Broken]
Question 3.
I can easily derive the equation I need, which is:
lamda = h/p
Which after some playing around with K.E =1/2mv^2 etc we obtain:
lambda (de brogile) = h/SQRT(2mKE)
Here is the data we are provided with in the exam (see sheet 1): http://www.strings.ph.qmul.ac.uk/~russo/QP/week6.pdf [Broken]
Everythings in eV and MeV, I plug in the values constantly, tried converting h to joules, and the electron mass to kg etc, but no avail as I don't think I know what Im doing with it, and I can't seem to obtain the real answer which is: 1.2 x10^-9m
Anyone explain how to do this quickly? I understand the theory behind this top notch but missed on how to use eV etc.
THANKS.
Answers and Replies
Matterwave
327
The equation appears to be right (I plugged in values and got the right answer), what kind of answers are you getting? It's probably just an arithmetic error, or a unit error.
Lavace
62
Thanks for the reply!
I plugged in:
4.14x10^-21 / SQRT(2 x 0.511 x 1.6x10-24) = 3.2 x 10-9.
I converted 1eV into MeV. Where am I going wrong with this?
If I convert everything to eV and use:
4.14x10^-15 / SQRT(2 x 511 x 1.6x10-19) = 3.2 x 10-7m
Still wrong, and I'm ripping my hair out on this!
Matterwave
327
Well, when you use electron volts, what speed comes out? It's not meters/second, but rather c.
Also, you have some wrong values. The electron is 511keV = .511MeV (correct for your calculation in MeV) = 511000eV (incorrect when you plugged it in eV).
Also, you're converting 1 eV into joules which doesn't make sense since you used everything else in eV.
Lavace
62
So how would I go about doing this?
Would I multiply the value of the rest mass by (3x10^8)^2 to obtain the MeV value?
Matterwave
327
no, because then you get a dimensionless unit (or /s or something weird like that).
What you want to realize is first, don't convert your 1eV into 1.602*10^-19 Joules, and 2 at the end realize that your answer is given as a fraction of c (times seconds).
How would you then convert the answer to the correct one? Well, multiply your answer by the value of c.
The units will be weird, but the procedure should get you the right answer at the end.
Suggested for: Urgent: de Brogile wavelengths of atoms, working in eV!
  • Last Post
  • Last Post
17K
  • Last Post
27K
  • Last Post
  • Last Post
