USB to Serial Converter
  • Thread starter Jobrag
28
I have a Prolific USB Serial Convertor which has been assigned COM 6. When connected to a device that allows 6 serial ports it works fine. I'm now trying to communicate with a device that only allows up to COM 4, how do I reassign the USB converter to COM 4 or less?
I'm running WINDOWS XP 2002 on a DELL laptop.
Answers and Replies
MATLABdude
If you're like me and you had COM ports being enumerated starting in the double digits, the following can be used to reset the enumeration (WARNING: requires registry modification):
http://www.bisque.com/sc/forums/p/446/430.aspx
Or you can just manually do it, as per the post above me.
28
Thanks guys I now have an additional problem, the ports 1 to 5 are all described as being used, how do I identify what is using the port so that I can decide which one to change?
MATLABdude
If you open up the Device Manager (accessible through the Control Panel), expand the Ports section (click on the '+' sign), and then plug in your USB-serial converter, you should be able to see it get auto-detected (you may have to hit refresh).
Have you upgrade windows xp to service pack 3 ?. It may be solve your problem.
Related Threads on USB to Serial Converter
  • Last Post
  • Last Post
10K
  • Last Post
  • Last Post
  • Last Post
  • Last Post
15K
  • Last Post
F
  • Last Post
  • Last Post
  • Last Post
