Fortran Using 2D array in dat file
  1. Mar 4, 2016 #1
    Hello everybody,
    I have a source code which gives me as a result an array of 2 columns and 3001 rows (2d array). By using fortran90.
    I was trying to have the values inside these cells in to .dat file and tried to generate a subroutine and call my main array inside this. But somehow I get errors. Linking the code below any help is appreciated.
    Code (Fortran):
    program hw1
    REAL G, Ks, DVIS, EPS,LENGTH,D,Vs,Re,Vi,V0,FFACT,DELt,I,Vi1,J
    INTEGER H, T, PHO
    real, dimension(3001,2):: VTARR
    G=9.81
    D=0.3
    H=8
    ks=0.0001
    T=60
    DVIS=0.001
    PHO=1000
    EPS=0.01
    DELt=0.02
    WRITE (*,*) 'INPUT CYLINDER DIAMETER D:'
    READ (*,*) D
    WRITE (*,*)'INPUT PIPE LENGTH L'
    READ (*,*) LENGTH
        IF (LENGTH==50) THEN
            Vs=6.586        !10.2655
        ELSE IF (LENGTH==100) THEN
            Vs=5.00
        ELSE IF (LENGTH==200) THEN
            Vs=3.669
        ELSE IF (LENGTH==500) THEN
            Vs=2.36
        end if
        Re=PHO*Vs*D/DVIS
        FFACT=0.25/((log10((ks/(3.7*D))+(5.74/Re**0.9)))**2)
        J=1
        do I=0.02,60,0.02
            IF (I==0.02) THEN
            V0=0
            Vi=DELt*H*G/LENGTH
            VTARR(J,1)=Vi
            VTARR(J,2)=I
            J=J+1
            WRITE (*,*) Vi
            ELSE IF (I/=0.02) THEN
            !Re=PHO*Vi*D/DVIS
            !FFACT=0.25/(log((ks/(3.7*D))+(5.74/Re**0.9)))**2
            Vi1=Vi+(DELt*(H-((1+(FFACT*LENGTH/D))*((Vi**2)/(2*G))))*G/LENGTH)
            Vi=Vi1
            VTARR(J,1)=Vi
            VTARR(J,2)=I
            J=J+1
            END IF
            WRITE (*,*) Vi
        end do
        CALL outputdata(VTARR)
    PAUSE
        END PROGRAM
    SUBROUTINE outputdata(X)
      implicit none
    REAL,DOUBLE PRECISION, INTENT(IN) :: X(:,:)
       integer :: i
       ! output data into a file
       open(1, file='data1.dat', status='new')
       do i=1,ubound(X,1)
          write(1,*) x(1,i), X(2,i)
       end do
       close(1)
       ! opening the file for reading
       open (2, file='data1.dat', status='old')
    end
    <<Moderator's note: code tags added. Next time, you must do that yourself, otherwise your post may be deleted.>>
  3. Mar 4, 2016 #2
    DrClaude
    Staff: Mentor
    We are not psychics. If you do not tell us what the errors are, we can't help you.
  4. Mar 4, 2016 #3
    Oh yes Ofcourse. I get this error now:
    C:\Users\hasan.dalgic\Documents\Visual Studio 2012\Projects\Console2\Console2\hw1.f90(52): error #7978: Required interface for passing assumed shape array is missing from original source. [VTARR]
  5. Mar 4, 2016 #4
    DrClaude
    Staff: Mentor
    You can't pass array X to the subroutine without either passing its size or making an interface for the subroutine:
    Code (Fortran):
    program hw1
      interface
         subroutine outputdata(x)
            real (kind(1.d0)), intent(in) :: x(:,:)
         end subroutine outputdata
      end interface
    Note that you cannot use DOUBLE PRECISION as you did. Also, J should be an integer, as wll as I (you should not have a do loop with a non-integer variable).
  6. Mar 4, 2016 #5
    Now I modified my code as it is below. But still I get the error:
    - A specification statement cannot appear in the executable section.
    Code (Fortran):
    program hw1
    INTEGER H, T, PHO
    G=9.81
    D=0.3
    H=8
    ks=0.0001
    T=60
    DVIS=0.001
    PHO=1000
    EPS=0.01
    DELt=0.02
    READ (*,*) D
    READ (*,*) LENGTH
            Vs=6.586        !10.2655
            Vs=5.00
            Vs=3.669
            Vs=2.36
        end if
        Re=PHO*Vs*D/DVIS
        J=1
        do I=1,3000,1
            IF (I==0.02) THEN
            V0=0
            Vi=DELt*H*G/LENGTH
            VTARR(J,1)=Vi
            VTARR(J,2)=I
            J=J+1
            WRITE (*,*) Vi
            !Re=PHO*Vi*D/DVIS
            Vi=Vi1
            VTARR(J,1)=Vi
            VTARR(J,2)=I
            J=J+1
            END IF
            WRITE (*,*) Vi
        end do
    PAUSE
    INTERFACE
        SUBROUTINE outputdata(VTARR)
            real (kind(1.d0)), intent(in) :: VTARR(3000,2)
        END SUBROUTINE outputdata
        END INTERFACE
        END PROGRAM
      implicit none
    REAL, INTENT(IN) :: X(:,:)
      INTEGER I
       do I=1,ubound(X,1)
          write(1,*) x(1,I), X(2,I)
       end do
       close(1)
    end SUBROUTINE
  7. Mar 4, 2016 #6
    DrClaude
    Staff: Mentor
    The interface has to appear right after the program statement, like in the example I posted.
  8. Mar 4, 2016 #7
    But I find my value to be used inside subroutine at the end of the program. And it will be my variable in subroutine. By the way can I assign ubound(array) in to integer variable? I tried it but it was a failure aswell. I am a VBA user and this language is a bit unusual for me.
  9. Mar 4, 2016 #8
    DrClaude
    Staff: Mentor
    It should work:
    Code (Fortran):
     integer :: i,imax
      imax = ubound(X,1)
      do i=1,imax
      end do
      close(1)
  10. Mar 4, 2016 #9
    Now the problem is what I get as a result of my main program is VTARR(3001,2) named and dimensioned array.
    How can I write a subroutine or a function that sends the values inside this array in to .dat file?
    Something similar to this but it won' t work as a separated subroutine or function:
    Code (Fortran):
    imax=UBOUND(VTARR,1)
    PAUSE
    I=0
       do I=1,imax,1
          write(1,*) VTARR(I,1), VTARR(I,2)
       end do
       close(1)
  11. Mar 4, 2016 #10
    DrClaude
    Staff: Mentor
    I don't understand. What you wrote should work. Can you explain better how what you want should be different from that?
  12. Mar 4, 2016 #11
    Yes it works inside my main program when I write it. But I want to write it outside my main code and use it as a function.
    So that I can send various arrays in to this function and get the .dat files from each of them.
    NOT RELATED TO THİS TOPİC: By the way how can I add "," as a string in between my write(1,*) VTARR(I,1), VTARR(I,2) in order to have format required by datplot program. I need "," in between 2 columns of this array also.
  13. Mar 4, 2016 #12
    jtbell
    Staff: Mentor
    Code (Fortran):
    write (1,*) VTARR(I,1), ',', VTARR(I,2)
    By the way, you're asking for trouble by using plain 'I' as a variable name. In some fonts, it's very difficult to see typographical errors involving 'I', '1' and 'l'. :mad:
    (also 'O' and '0')
Have something to add?
Draft saved Draft deleted
