Using Bernoulli's equation
  • Thread starter pyroknife
pyroknife
613
Part a is pretty easy
m'1+m'2=m'3
m'=mass flow rates
density1*velocity1*Area1+(analogous terms for inlet 2)=(analogous terms for inlet 3)
The 3 densities are unknown
but can be found from equation pressure/(RT)
R=286.9 J/(kgk)
This gives:
density 1=1.66 kg/m^3
density 2=1.432kg/m^3
density 3=2.35 kg/m^3
solving for mass flow rate gives 7.128 kg/s
not for part B our professor told us to use the equation
Q_dot_in - W_dot_out = m_dot_3 (cp T3 + V3^2/2 + gx3) - (analogous terms for 2) - (analogous terms for 1)
cp=specific heat =1004 J/kgK
h=cpT so that's where those terms came from
V1=Q1/A1
V2=Q2/A2
V3=Q3/A3
Where Q=volume flow rate given in the problem
this gives:
v1=86.61 m/s
v2=66.1m/s
v3=33.41 m/s
The equation also requires mass flow rates
mass flow rate = density*Q or density*velocity*area
m'1=4.98 kg/s
m'2=2.15 kg/s
m'3=7.128 kg/s
Now we have all the unknowns and the energy equation becomes
67-W_dot_out = 7.128 (1004*311+33.41^2 / 2 + 9.81*.5) - 2.15(1004*365 + .5*66.1^2+9.81*0.5) - 4.98(1004*294+.5*86.615^2+9.81*0)
W_dot_out = -118 kJ/s
W_dot_in = 118 kW
However the answer is supposed to be 223 kW or something like that.
I checked our my answer a few times and haven't found any mistakes. Can you guys check?
Answers and Replies
cmmcnamara
122
Hmmmm odd. Is the "correct" answer given in the back of the book or given by your professor? I too came up with 118kW.
pyroknife
613
Sorry, never mind, he just told us it was the wrong answer. UGHhhh
Suggested for: Using Bernoulli's equation
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
